The Shipyard ( Dry Dock ): Builds & Questions => Submarines => Topic started by: Telusboats on February 06, 2015, 07:30:54 am
does anyone have plans for a tech rack for Robbes U47 that will accommodate the Engel 750 ml tank?
There's a company called pirahna models in Germany that offer one for sale
http://www.modelluboot.eu/Preisliste.htm
The website isn't very good but drop the chap an email and he'll send you all the information and pics you need. I have the Sea wolf Tech rack awaiting construction in Finland
There's another outfit that produces a plastic tech rack, that looks almost identical to the type fitted in the Engel Lafayette.
Don't know if they have a website, but if you're on the book of faces, they have a page there-
https://www.facebook.com/pages/Modellbau-Wikinger/753073014783452
(http://img.photobucket.com/albums/v293/subculture84/u47tech_zps80513f50.jpg) (http://smg.photobucket.com/user/subculture84/media/u47tech_zps80513f50.jpg.html)
.....strange. My previous posts, images and responses have all disappeared from this thread.
Is this common?
What happened to all the posts?
.....not just me then
If I was to hazard a guess, modelboatmayhem has had its fair share of database errors or site wide outage. I wonder if during the work to get it back and running, some data was lost. Admin, can you help?
We did loose a days input, so a few letters cannot be recovered.
....anyone interested in starting again?
I would as I am working on a u47.
Hi.
one here.
http://www.ebay.de/itm/U-boot-Technikgerust-passend-fur-Robbe-U-47-Modelluboot-/161681536847?pt=LH_DefaultDomain_77&hash=item25a4f8774f (http://www.ebay.de/itm/U-boot-Technikgerust-passend-fur-Robbe-U-47-Modelluboot-/161681536847?pt=LH_DefaultDomain_77&hash=item25a4f8774f)
frank
I am in Canada and would like to avoid transactions that are from outside North America. Is it possible for someone to send me the templates or instructions for the tech rack?
You should have no trouble getting them posted, sent plenty across the pond with no issue.
Posted, as in by the mail system?
Well I think the carrier pigeons would struggle to cross the pond...
Dose anybody know of a sure way to get the rear of the Robbe U-47 to fit snugly to the rest of the body? mine simply wont join up properly, i :-) can't complete it otherwise. Thanks.
Just another random question...
What size dive tank do you need for the U-47, Is it the 750ml one from Engel?
I have one of these in the loft nearing completion but then I changed my mind from the kit and wanted to make it a static diving sub and that's where it stopped.
Craig.
the best way to create a seamless connection between bow and stern sections is to glue two sheets of .040 abs to the edges of the existing abs "body", but perpendicular to the body... with a hole cut in the middle for the WTC. its kind of hard to describe, but i will post pictures this evening of mine, when i get home from work. basically instead of having the rough edge of the existing body pieces you will have two sheets of abs butted against each other.
Craig.
i built mine with the 750ml tank, but in all honesty, a 800ml tank would work better... it was a struggle to make mine work with the 750ml
Many thanks for that, I'll have a look around for a tank 800ml or bigger then. :)
Would be good to get that back out the attic and progressed some more. I have the rivet kit, decks and resin conning tower from a German company that I think are no longer going. The conning tower is a model in itself.
Craig.
Engel will make you a tank to a specified volume, always the same diameter however. They just vary the length.
Largest standard size is 825ml.
What you need to watch is the pressure building up inside the boat, as that can compromise hull seals if it gets too high.
That's what I'm after thanks, any piccies of the boat in half by any chance please? btw what did you use to attach the two faces? Ta.
Anyone know where I can get hold of this abs 0.04 sheeting? I'm in Herts. Ta.
Easier to find metric sizes in the UK. 1mm being closest. To be honest any plastic sheet would do, just bond it in with modified acrylic. Ebay is a good place for small quantities of plastic sheet, try typing ABS plastic sheet.
Does tend to be more expensive than other plastics though.
That's what I'm gonna try mate, I've ordered a couple of sheets of abs A4, it's black but that doesn't matter, I can always go over it later. Ta everyone, and viva Nth London. ;)
Didn't mean to leave you guys hanging on this... two shots of the internals... the two pieces on fore and aft that appear somewhat "white" are what i am talking about. as you can see, when the hull is closed, the two pieces of ABS lay against each other. start by taking two sheets of styrene (i used .040, but anything will work) , cutting a 4" hole into them, so they slide over the internal WTC cylinder, and tape them together so there is zero space between them. close the two pieces of the WTC together, and then either glue the rear external hull in place as the instructions indicate, or temporarily hold the rear in place so it doesn't move. use plastic "weld" type glue to glue the sheets to the appropriate external hull parts. after the two sheets have basically been solidly attached to the corresponding original skins, shave the two sheets down until they follow contour of the external hull. putty and sand until the seam between the original hull and the new sheets is gone.
any more questions, ask, and i promise i will answer
metrically speaking, 1mm sheet would basically be the equivalent of .040"
as to the tank size.... its difficult to know exactly what the best size is... like i said 750ml can be made to work, but it also has to do with the fact that there is a limited amount of space inside the cylinder. much larger than the 750ml, and you also have to start looking at how much room is needed for the piston rod, and how far the tank has to be moved to make room for it. I will post another pick of where and how i have the tank situated.
Okay,
two photos.
this is a custom built 1/8" acrylic addition to the original tech rack. designed to allow for the addition of the tank, without all the leftovers for the lead acid batteries. on the top, from rear to front: three servos, rear dive planes, rudder, front dive planes. two 400 size graupner motors with 3:1 planetary gearboxes, motor speed controller, ballast tank. in front of the ballast tank is space where the ballast tank controller and receiver were located. on the bottom, from rear to front: 5 cell nimh battery, ballast tank, and room for 3 more 5 cell nimh batteries. the battery packs were each 3000mah, giving me a total of 6v 12000mah for the battery. speed controller fed the receiver. for the specifics, the way it was setup, the rear of the ballast tank is 280mm from the inner edge of the rear endcap. the plastic tube that you may see some of in the photos for the piston rod to go through ends 65mm from the inner edge of the rear endcap (the 1/2" white "line" running between the motors). in all honesty, i think the ballast tank could be moved a little further forward, based on the amount of foam i had to put in the stern free flooding section. maybe 20mm further forward.
the big white strips you see underneath the ballast tank are lead weights
the brass tube running along side the tank is an 8mm ID tube to feed the ballast tank. it is in two pieces. one is soldered to ballast tank, one is bonded to endcap. the 1"+ piece of shrink tubing links the two together where the ballast tank motor is located.
Is it a big job to convert to a pump system? How much are those 800 pumps? Would I need new batteries etc. to make space? I'd better get my boat wet first. :embarrassed:
Silent Running,
yes, it is a big deal to make the U47 a static diver. due to space, the original batteries cannot be used, new batteries that fit in areas that were unused before must be made... why? because the space where the original batteries go is where the tank goes. to buy the engel 750ml tank and controller is going to cost about 220 euros. new batteries (in my design) were another 70 euros. then all the time and work to make the changes to the tech rack
