Model Boat Mayhem - Forum
Technical, Techniques, Hints, and Tips => Detail Work, Rigging, Fittings, Figures Etc. => Topic started by: destroyer42 on July 24, 2007, 08:35:49 PM
Hi Has anybody built a working towing winch? If so how is it done? I have been looking at a graupner motor connected to a worm gear and then to a cog which will turn the cable drum utilising a small speed controller.
Any ideas.
destroyer42
ask catengineman, he's done a few, for himself and for me, he'll put you right
i found the best way is to use a battery screwdriver mounted in the hull then have a n imitation winch with spinning drum on deck will try post some pics later
Hi destroyer42,
I saw a very good working winch on a model at the Wings & Wheels show a few weeks ago.......
(http://i136.photobucket.com/albums/q168/MBmayhem/DSCN5730.jpg)
(http://i136.photobucket.com/albums/q168/MBmayhem/DSCN5492.jpg)
(http://i136.photobucket.com/albums/q168/MBmayhem/DSCN5739.jpg)
(http://i136.photobucket.com/albums/q168/MBmayhem/DSCN5740.jpg)
(http://i136.photobucket.com/albums/q168/MBmayhem/DSCN5731.jpg)
Hi Guys,
Thanks for the info and the pictures. Hope catengieman can give me some further advice on this subject .
destroyer 42
...Hi Guys...
Here is a picture of the Working Winch Set-Up in my Shoalbuster tug...
An Electric Screwdriver Motor & Gear Box stood upright in the hull with the drum made from a 6mm allen key & 2 discs from a Servo...Powered by 3 x 1.5 volt batteries & controlled by a Speed Controller...The Tow Rope can be passed through a hole in the front or back of the Deckhouse over the drum of the Dummy Winch on Deck & out to the Tow...
The Winch can be laid across the hull or stood up in the hull, depending on the space available...
...Best Regards...Norry...
