Mess Deck: General Section => Tugs and Towing => Topic started by: Fastfaz on August 31, 2015, 05:03:22 pm
Yo all,
Can anyone help/advise me how to make a towing winch that works with suggestions for the layout where everything goes etc? I remember seeing a post from Norry (Glasgow) about how to do it but can I find the post "platting chance fog of more". The winch needed a motor from a cordless screwdriver which I have acquired but after that my brain, if I have one that is, has come to a stop. Help needed.
Cheers all, back to the cider.
Faz. <:(
Could you use the switch from the screwdriver still wired in and then use a servo to operate it? You can get high torque servos. You might be able to remove the spring from the switch to make it easier to operate remotely.
If not can you use a high ampage ESC and an auxiliary channel with a three way option so you have neutral?
Destroyer42 on here made a good one
http://www.modelboatmayhem.co.uk/forum/index.php/topic,51370.msg525563.html#msg525563
Might be best also putting the subject topic name and what page it was on as this link just goes to the front page - oops - sorry was in guest mode - it works :embarrassed:
I quite fancy a working winch on a build I have coming up.
There are quite a few here on Mayhem:
http://www.modelboatmayhem.co.uk/forum/index.php/topic,10770.msg101113.html#msg101113
http://www.modelboatmayhem.co.uk/forum/index.php/topic,42507.msg429034.html#msg429034
http://www.modelboatmayhem.co.uk/forum/index.php/topic,5141.msg51973.html#msg51973
http://www.modelboatmayhem.co.uk/forum/index.php/topic,34751.msg349905.html#msg349905
Also:
http://www.dahmen.de/cat9166.html
http://www.cornwallmodelboats.co.uk/acatalog/krick_winches.html
http://www.ebay.co.uk/itm/RC4WD-1-10-Warn-9-5cti-SCALE-Working-Winch-METAL-hook-MOUNTINGS-Need-Control-/131422518403?hash=item1e99647c83
http://www.ebay.co.uk/itm/120890398573?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D120890398573%26_rdc%3D1
