The Shipyard ( Dry Dock ): Builds & Questions => Steam => Topic started by: petesubman on November 14, 2015, 08:18:06 am
Has anyone ever done a soft solder repair to a wilesco steam block ,one of the threaded steam connections has come away, any information on how to go about this would be great, regards pete
Hi Petesubman
What material is the block made from ?
Spud
The block is brass but nickel plated which may not allow soft soldering any help with this would be appreciated regards Pete
Bonjour,
If you could remove ALL the glass parts of the boiler, I would suggest you to use sodium silicate :
https://www.youtube.com/watch?v=TRh2TG50T6c
If the boiler is completely filled with the mixture, you do not need much pressure to have the repair.
Thanks for your reply Raphael, the problem is with the valve block connections not the boiler regards pete
Bonjour Pete,
Sorry, could you share with us a picture, that would help and avoid misunderstanding ;) ?[size=78%] [/size]
I have repaired a willesco d48 valve block using the 5% silver bearing solder. Cleaned it up well to remove oil, removed the plateing from the pipe and block using emery cloth and a drills bit.
Thanks for that steam boat, trying to find some pics Raphael, regards Pete
