Technical, Techniques, Hints, and Tips => Other Technical Questions... => Topic started by: Norman Castle on November 27, 2015, 02:48:49 pm
I've now handled four Caldercraft "Fineline" stainless M4 propshafts - one 7", one 5" and two 4". The 7" one is fine, but the other three all exhibit run-out at one or both ends. The amount of run-out is not consistent between shafts or at each end of the same shaft, but it's clearly visible when the shaft is rotated by hand in the tube. By the time the coupling adaptor's gone on, the total run-out at the motor end of the coupling is ample to create vibration and noise.
I've established beyond any doubt that this is not due to damage in transit: they were definitely made/threaded wonky. Have I just been very unlucky indeed, or is this par for the course with these shafts?
And if I want a simple M4 propshaft assembly (say 4" or 5"), where can I buy a decent one online? Anybody know what this range (http://www.ebay.co.uk/itm/4-MODEL-BOAT-PROP-SHAFT-4mm-INNER-SHAFT-/191471519236?var=&hash=item2c94978604:m:mEoHRIA5cpTwQ2llSQd_F5A) is like?
SIMPLY the BEST m8 That is Steve Tranter of Model Boat bits I can vouch for his shafts....why....MMMM lets see ...Ive got over 15 of his shafts in my boast wont buy NOW WHERE else
So I guess you like them then ... {-)
Thanks very much indeed Dave. I'll give one a go for the next build.
I now use Steve's shafts and tubes, too. O - and his little flexible couplings! And his P-brackets..... and his tiller arms....
DM
DM
OK ... message received and understood :-)
He did the custom shafts for my Tamiya Tirpitz
Special order cut and made up to my specifications. Still received within 2 days of ordering
