Technical, Techniques, Hints, and Tips => Wood Care: => Topic started by: Hande on February 01, 2016, 06:28:17 pm
In my Billing boats kit came the large plywood deck piece.
May be because of a lengthy time in storage, it was bent overtime.
And it has a strong memory with that!
I have tried hot steam.
I have soaked the deck for 18 hours in warm water with vinegar.
But the plywood does not relax back to straight.
Right now - after the soaking operation - it is under tension into the opposite direction. I figure when trying to remember the bent form, it wouldn't have it to return all the way back.
Should I make a new one?
Should I attach some structure beneath to counter the bending tension?
I could make a couple of clamps to hold the piece straight - disguised as some movable equipment on the deck.
I would try exactly what you are doing, soak and then bend in the opposite direction and let it dry under tension.
After that it can only do one of three things, 1, go back how it was. 2, go back to flat. 3, stay bent in the new direction.
If I wasn't satisfied with the result I would just make a new one.
Is it possible that gluing it in position would help it to keep the correct shape? If it's only a little bent it may be ok!
Without knowing all the details the above is my best offer...... Good luck U2
Thanks U2!
It's the bottom of the removable superstructure. So glueing won't do.
To make it worse, the bent end is the one with just empty space (it's a tug). Under the boat house the house's rigidity would fix the problen.
I'm thinking it should stay straight by well positioned fasteners, when in place.
Maybe, with time, it may even straighten-up on its own.
It's just that I would hate it being all curved every time I take the superstructure off...
Now waiting for one of three possible outcomes from the unbending exercise.
I hope you get the result you are after. If bodgers can bend chair legs out of good thickness timber then you should be able to get your ply straightened alright.
I am trouble seeing how the ply will fit to the boat. Any chance of a picture?
Assuming, dangerous, the image I have in my head is correct.
If there is no support under one end. You could glue a straight square section timber under the ply to hold it flat, in such a position that it does not foul anything else. Alternatively, if you cannot really see into the superstructure, you could glue similar pieces of timber to the inside walls of the superstructure to provide more rigidity to the walls, and then glue the ply to that.
Solutions might depend on if the ply is curling up or down at the edges.
Without a picture it is hard to advise.
Hi weak amonia will bend ply like it is tissue paper.
Roy
Yes, Roy but it will also reduce its strength. Rather than keep messing about with it I would literally start with a clean sheet! Just use the old part as a pattern.
Hi Colin, I don't disagree but how much strength do you need in a deck on a relatively small boat. I have just "un-bowed some 6 mm ply 4' x 2' using hot water and heavy weights and that has been satisfactory. (Model railway baseboard)
Personally I would write off the existing ply and start again. I have done so in the past. Cost does not come into it as most would make a model they expected to last and using cheap materials is never a good idea.
All my models are still going strong apart from a couple of accidents and one dates back to 1964. Paint finish from my experience is a major factor in longevity.
regards Roy
Roy, yes, you are right, it would probably fit the bill but the quantities of material that go into models are so small in most cases that I personally like to keep the quality level up as much as possible! Just my preference.
Any chance of a photo of the piece and where it fits (or should fit) ....... U2
I really appreciate your interest and advice!
Here's the photo.
I'm totally with quality as a priority.
On the other hand, the original is laser-cut and no way I can make an accurate copy of it.
I don't have the means to saw straight - and there is the square hole there, too.
Would have to find facilities...
Use a Stanley knife or similar surely? Just cut round the original.
Something that's worked for me :)
Take the wood into the sauna with you, have a nice long sauna then place the sheet under some very heavy weight (I used 2 Tractor batteries)
This is a good one! Only connosseurs know what you are talking about.
My wood was already in the sauna, too. Something a finn would think about as a cure among the first things...
...and a steady hand, to be sure.
This [size=78%]may well end up there eventually.[/size]
If your model is the Smit Nederland, there should be 4 pieces of wood (pre-shaped) which fit together underneath the part you are trying to straighten. These should hold the ply in the correct position and with the correct deck sheer, like this:-
Here's the photo.
Hello
Having built 4 Billings kits for old to new ones . They all had one thing in common ,Poor quality wood that warps easily .Try what Ray has said about the 4 pre shaped wood glued to yours first . If that does not fix it the new wood time .
A tip for when building the kit . Photo copy all the parts. If you ever need to remake a part you have a full size template .
john
Uh-oh.
At the bottom of the last page of the instructions they show, indeed.
I expect them to fix my problem.
Thank you Ray!
I take it the S.N. is your build?
Thanks everybody for yet another learning experience!
I will photo copy everything right away. A good tip!
thanks, John
Hello
john
Uh-oh.
Thank you Ray!
Hi Hande, yep, the photo is from my rebuild here:-
http://www.modelboatmayhem.co.uk/forum/index.php/topic,52330.0.html
Hope you get your deck sorted - looking forward to your updates as well :-))
john
Excellent idea - I'll remember that one ! O0
There's a couple of chaps on here with laser cutters.... I'm sure one of them might be able to cut you a replacement for a few beer tokens :)
But do they live in Finland?
Ha a do they not have 'post' in Surrey Colin {-) ......... I even get bits from England here in France, it's AMAZING! :} ..........
But compare cost of sending awkward shaped item from Finland to the UK and back again with simply placing the original over a sheet of ply and cutting round it. Seems the long way round.
Yes, we get bits through the post in the UK too, trouble is they sometimes commence the journey as a single item...... ok2
But Finland has so much Birch that they may not like more birch wood being imported!
...the original is laser-cut and no way I can make an accurate copy of it.
I cannot cut well either. But you don't need to.
Cut to within 1-2mm of the line, and then using a sanding block, sand the rest. These thin ply sheets sand really quickly.
This also works well with complex shapes, and so no need to buy a scroll saw if you don't have the spare cash, or bench space.
Good one!
Great advice - thank you!
End-of-thread:
I give up.
I soaked and heated with a hot air gun. The wood was really hot. I put the piece under pressure while bending it in the opposite direction. The plywood fell apart in places. I glued in those places, and continued pressing.
Under the pressure it didn't dry very well, but after it dried, it looked promising - for a while. - After two days, it was all screwed again (probably it wasn't all dry, after all...). It's the screwed bend that makes the situation worse. The force is enough to bend the frame, which is made of 5mm plywood.
Having the plywood brake between its layers makes me conclude that the part is lost for good.
The 5mm plywood parts of the frame were bent, too. With hot air, it was relatively easy to un-bend them. I feel good about the frame. Now going to buy a fresh sheet for the sub-deck and practice cutting from scratch. No harm there - hopefully learning something new, again.
Thank you everyone!
One thing I haven't seen mentioned here, would be to borrow the management's steam iron, steam the back side for about 5 minutes and then clamp to a flat surface for about 24 hours. It works putting a curve in, so it might take one out.
Cheers Jim W
Is the piece removable? If not I'd just glue it in position and clamp it. If it is I would glue stiffness to the underside and clamp them until dry. U2
Another trick is to seal the reverse side, anything will do, paint, polish, etc.
