Technical, Techniques, Hints, and Tips => Engineering Techniques and Materials. => Topic started by: pipercub1772 on April 05, 2016, 09:54:39 am
Hi, On the set up I have the prop shaft will be much lower than the motor shaft were can i get some type of pulley system to connect prop to engine.
Kind regards,
Alan.
Try MFA at http://www.mfacomodrills.com/timing_belts_timing_pulleys/timing.html You should find something to suit.
Barry M
Thanks Barry that looks perfect ,Kind regards Allan.
