Technical, Techniques, Hints, and Tips => Engineering Techniques and Materials. => Topic started by: Brian60 on April 15, 2016, 07:48:21 pm
I'm after some sealed bearings, inner 5mm outer 15mm. Does anyone have a website link that I could search or and address of a supplier please.
https://www.servocity.com/index.html
http://www.ebay.co.uk/itm/10-PCS-Miniature-Rubber-Sealed-Metal-Shielded-Metric-Radial-Ball-Bearing-Model-/400458020258?var=&hash=item5d3d2875a2:m:m1QgCLyXXR9mV69ZkMmxyzQ
Brian, having used www.simplybearings.co frequently over the past ten years or more and always found what I wanted at the price I wanted and had it delivered cheaply in next to no time, I can strongly recommend this company.
Trevor
Another shout for simply bearings.
Same as the last two post ,simply bearings, bought bearing for the band saw , also O rings .
Good service .
David
Thanks guys, I'll check them all out.
If you need bearings in future Brian (or anyone else :-)) ) give me a shout I'll see what I can do for you, I can get them for you at cost price + postage I have thousands in stock and hundreds of thousands available for next day, I can also get Oilite bronze bushes, PTFE bushes should you need them
If I can help anyone out in any way give me a shout
:-)) Cheers Paul, noted in my book of useful notes O0
No worries :-)) I do all types of bearings, seals, even small timing belts like the ones used between motor/prop
