Technical, Techniques, Hints, and Tips => The "Black Arts!" ( Electrics & Electronics ) => Topic started by: The Old Fart on May 13, 2016, 04:16:17 pm
http://www.banggood.com/Sound-Unit-for-RC-Tractors-Programming-Cable-for-RC-Tractor-Sound-Unit-p-1035339.html
Hi guys,
I've received one of these 'knock off' units.
It works very well, giving variable engine sounds, and aux sounds.
Fairly easy to program the unit, but it doesn't like windows 10, what does?
Has anyone managed to put there own sounds into the unit.
22050Hz @ 8bits mono is required.
I've used Audacity and AVS sound editor, but when uploaded to TBS-Flash, is says the sound file is corrupt.
TOF
Those software screenshots look like the programming software for the DigiTrax Locomotive sound modules for model railways.
I had an awful job getting the sounds to upload to the digitrax decoders.
It took ages to get the sound files exactly to the format it liked. Sadly this was several years ago now and I cannot remember the settings :(
had a problem with there old units with window 10. ended up running it xp compatibility mode and worked.
