Mess Deck: General Section => Chit-Chat => Topic started by: Onetenor on May 27, 2016, 12:58:33 am
Hello I have not done much with boats especially in last 40 yrs Now 73 and waiting for new hips and can't get out at present Live in Meliden Nr Prestatyn N.Wales I am looking for an old plan which was in the old MAP plans hand book It is a float.sponson air driven hydroplane 3 Sponsons 1 in front two at rear on a sort of wing .Serpentine shaped body / fusalage . Motor on front of the pylon and rudder at rear. Body is ply core with balsa either side, Sponsons built like a wing with a thick section ? Balsa with thin ply skins .I made one in the 50s and would like to do another with R,C. Maybe a much bigger version . Any one out there recognise the model? Thanks for reading John :} :-))
It is a float.sponson air driven hydroplane 3 Sponsons 1 in front two at rear on a sort of wing .Serpentine shaped body / fusalage . Motor on front of the pylon and rudder at rear. Body is ply core with balsa either side, Sponsons built like a wing with a thick section ? Balsa with thin ply skins . Any one out there recognise the model? Thanks for reading John :} :-))
Hi John,
Something like this "Skater" by Vic Smeed? (http://www.myhobbystore.co.uk/product/16722/skater-mm312-plan)
If not then there are other hydroplane plans available (http://www.myhobbystore.co.uk/browser/5556/hydroplane) on the same website...
Hope this helps.
Mark
Any good?
Thanks peeps Skater it is . Couldn't recall the name I was thinking PONDSKATER Brilliant I had one Went like stink. Now need to dp an R/C job next
Good Grief!
I built one of these before Pontius pilot even sat in a cockpit. It had a dreaded Wen-mac 049 for power with a KK 3-bladed prop
Fabulous on water, but the best fun came on ice - I lived in Scotland, and the local lochan froze over. My brother and I tried skater on the ice - it went like the wind, but was just sliding on the "floats" so as a quick way to get some stability we screwed a razor blade to (just) touch the ice.
Now it was really impressive, but the fuel always ran out way out on the ice - so my brother (sea fisherman) would cast beyond it with a treble hook and tow it gently back to the bank.
AHHHHH, nostalgia isn't like it used to be :-) [size=78%] [/size]
[/size]I also made a device from Pop Mechanics - which was a large body with 3 legs and tinplate "feet" which allowed it to water-ski. I think this was called pond-skater or similar. The year must have been about 1964 or 5andrew[size=78%]
I seem to be reduced to 78%!
I hope my waist goes down in the same ratio
andrew
100% really
Good Grief!
[size=78%]
You knew Pilate too then. Mine had a JB Atom 1.47 cc on it Almost flew.[/size]
