Technical, Techniques, Hints, and Tips => Batteries & Chargers => Topic started by: PhilandIom on June 13, 2016, 09:55:36 am
Hi all, I bought an unbuilt model boat hull, it came with new in bags batteries, 2 x 5 cell Deans marine and 1 x Overlander 5 cell. I have no idea how old they are but I'm guessing at least five years. They are completely untouched or charged 6 volt NI-MH.
Is it worth my time and effort to recharge and cyle them a few times to see if the hold charge or save the effort and buy new?
Thanks, Phil
I would start charging at a low Amp rate. Less loading. If they charge up they should be fine thereafter.
If they refuse to charge or only partially charge then you may have to invest in new ones. Having said that new batteries (in their original packaging) can often sit a long time on shelves before being sold. Provided they have been stored at a reasonable temperature and not got damp they should be fine
A nicad cycler would charge them & see what capacity they are. If they have never been used they maybe OK, if left discharged then they tend to die.
NiCads, if properly discharged with an external load, can be brought back to life by proper recharging. They can be stored virtually indefinitely like that and if gently reformed will be like new ones.
If they were allowed to self discharge over time, different chemistry happens, and they don't always come back.
So yes it is worth trying if they look OK.
Please note that this question was about NiMh batteries. The last two posts were about NiCd's
