Model Boat Mayhem - Forum
Technical, Techniques, Hints, and Tips => Engineering Techniques and Materials. => Topic started by: Norman Castle on July 02, 2016, 01:11:18 PM
Title: K&S tubing
Post by: Norman Castle on July 02, 2016, 01:11:18 PM
Can anybody please tell me which size K&S tubing I need to make hinges with 18SWG piano wire?
Not really fussed if it's ally or brass.
Title: Re: K&S tubing
Post by: derekwarner on July 02, 2016, 10:52:47 PM
Norman....when you do the simple calculations, you will see the nomination of #18 gauge piano wire @ 0.048" diameter is not a good selection for 1/16" OD x 0.014" wall, nor 3/32" OD x 0.014" wall K&S brass or copper tubing........... Derek
Post by: Kipper on July 02, 2016, 11:01:28 PM
You could try these people, they do 'needle tube'. http://www.graysofkilsyth.com/salmon-needle-tubes.htm (http://www.graysofkilsyth.com/salmon-needle-tubes.htm)
The 1.8mm o/d tube may well be about 1.3mm internal, which would just fit your 18 piano wire.
Post by: derekwarner on July 03, 2016, 01:35:16 AM
Norman......just thinking outside the square.......
You could consider 1/16" OD [0.0625"] K&S brass round stock with K&S 3/32" OD brass tubing
These two sized elements provide a reasonably firm telescoping tolerance and both suitable for soft or silver soldering
The 1/16" OD brass material is only approx. 0.014" larger than your #18 gauge wire
Post by: Norman Castle on July 03, 2016, 10:59:08 AM
Got there in the end ...
K&S 5/32" nominal ally tube + 18SWG piano wire makes me a satisfactory hinge  :-)
Post by: Norman Castle on July 03, 2016, 03:00:42 PM
Just realised I typed 5/32" instead of 3/32" ...  :embarrassed:
Post by: Norman Castle on July 04, 2016, 12:56:44 PM
And I now know that brass tubing in SWG sizes from 20 up to 6 is readily available  :-)
