The Shipyard ( Dry Dock ): Builds & Questions => Working Vessels => Topic started by: neilesmith on August 20, 2016, 07:15:34 pm
I first posted on the beginners section as Calypso is my first radio control boat & I needed advice which was given & proved helpful so I decided to share my experience here. If Calypso is a representative example of Billing kits then I shall certainly not buy another. It's a shocker, especially at the price, so I rather regret my choice but it's not the first time I have had to make a silk purse from a sows ear so I'd better get cracking. At the start they suggest checking all the parts. Well DON'T not if you value your sanity. I spent over an hour trying to find just one part shown on a drawing & in the parts list but nothing like it anywhere while at the same time I have a pile of wood strips with dimensions that are nowhere in the parts list. Drawings of the laser cut sheets don't match the actual sheets (laser cutting is great but the sheets are all warped, can you iron plywood?) major parts don't match the plans & the instructions are pathetic. I could go on but lets stop being negative & sort it out.
I am still "getting my head round" the project & waiting for the famous book to come from Amazon so there will not be much to report for a while. Still I have had a success with a task I thought rather daunting, trimming the hull. A great opportunity to make a real dogs breakfast 'till I saw a mention of special scissors on another forum & tracked some down here: http://www.modelsport.co.uk/index.php?search=1&search_string=core+rc+scissors&x=12&y=11
I bought the curved & the straight but you only need the curved as counter-intuitively they are better for cutting straight lines. So the hull is trimmed with just a little sanding to do.
As this is your first boat kit, what you are finding is that there is a gulf between a plastic kit and a model boat.
Our hobby is very small and many kits require a lot of modelling work to complete them. Trimming the hull back is a stadard job and as you say, it can go wrong.
Calypso is a very old kit and a complicated boat - probably not idea for a first model when there are a lot of techniques to pick up. However, I'm sure there will be plenty of help and support here. It would be a good idea to see if there is a model boat club near you where you can chat to others, there may even be someone who has built this kit in the past!
I am still "getting my head round" the project & waiting for the famous book to come from Amazon so there will not be much to report for a while. Still I have had a success with a task I thought rather daunting, trimming the hull. A great opportunity to make a real dogs breakfast 'till I saw a mention of special scissors on another forum & tracked some down here: http://www.modelsport.co.uk/index.php?search=1&search_string=core+rc+scissors&x=12&y=11 (http://www.modelsport.co.uk/index.php?search=1&search_string=core+rc+scissors&x=12&y=11)
I have several sets of those scissors for prepping RC car bodyshells. A quick hint tho, Don't use them to cut any other type of material as the blades will loose their edge very quickly
Not quite my 1st boat , 1st r/c one. Sadly my nearest club is further than I am prepared to travel.
See my previous efforts in 1/90 scale
Oh good tip, thanks,
No probs
Looking forward to this build as its one kit I would love to build one day
So the bulkhead part 6 is 6mm too narrow & the base part 5 is too wide & will not fit between the shaft tubes as shown on the plan. Netleyned posted about a Calypso capsizing & sinking today & Shipmate60 suggested I omit the base to get the weight of the motors as low as possible so that will save me a bit of trimming. Thanks Bob
Neil.
As soon as I saw this I knew it had to be improved & sure enough came across a chap who had his rudder come adrift & also ran into another problem I had foreseen, access for maintenance. As I have plans to build extra animations into the model I am hoping to devise a scheme whereby the entire superstructure can be removed from the hull so any advice will be welcome.
Neil.
A couple of servo arms from my spares box. I ran a 2.5mm tap through them so when they are screwed on to the 3mm shaft they are a really tight fit & a locknut just to make sure. Servo placement & linkage will be determined later this was just to try it out.
Neil.
If I am going to succeed in making the superstructure removable the hull moulding needs to maintain the right shape so the stern has its curve corrected with a piece of scrap ply.
There's something going on in this picture which you can't see. I'll tell you about it later (if it works)......
What can be seen is a major problem where the forward bulkhead is too high. Other builders have encountered this but have not published what caused or how to overcome this fault. As the cabin structure is the same height as the bulkhead this is a serious error which I need to investigate.
It didn't work so will remain hidden.
The other problem is hard to figure out without an accurate plan of the ship. I'm hoping there will be one in the book I have ordered; "Jacques Cousteau's "Calypso" which I am waiting for as it is coming from the USA. My impression is that the hull moulding is about 3.5mm short in height for the bow section. If anyone knows better please enlighten me. In the mean time there is much else to be done. Despite many years as an active IPMS member I have never done a vac-form model so that is going to be interesting.
Neil.
So I'm marking around the parts with an indelible pen & cutting out with the scissors ready for sanding.
Also in this picture I have started preparing the planks for the decks. I decided 60mm would be about the right length for full size planks & as with HMS Victory am running round each plank with a soft pencil to simulate caulking.
A bowl of water with a piece of plate glass for a nice flat surface & a sheet of wet & dry. What could possibly go wrong? Well nothing at first, using 240 grade seem to work well & the funnel parts came out perfectly which made me overconfident so I went a bit too far with the submersible & need to use some filler. Nothing new here but my squadron signal white putty seems a bit hard & brittle with this plastic so I have ordered some Milliput epoxy putty which I hope will be more suitable. Some parts like the helicopter floats & the RIB I have decided are better glued together & sanded around the join.
At the start of this thread I asked (tongue in cheek) if you can iron warped plywood. No one replied so I tried it. Of course you can, but it doesn't solve the problem. My solution is to dilute PVA glue 50:50 with water, liberally paint it on both sides of the offending article & then using clamps, weights, & wedges set it 100% opposite the warp & leave for 24 hours. In the case of the largest part I have also glued stiffener strips to the underside. It works & hopefully will have the added benefit of sealing the wood ready for sanding & painting.
Nice to see someone using common sense and not just following Billings's instructions blindly, 1st rule of billings, throw away the shaft's, props and tiller arms and buy better ones.
My first Billing's boat was the Flying Fish, second was the Bankert and third was the Smit Nederland, I don't think I will do that again :) it's been 25 years since I built the Flying Fish for my dad, he's now 88 and still looks at it and say's hey son remember how useless those instructions were.
Not sure if it has been mentioned but please thoroughly scuff up anywhere you plan to glue anything to the hull.
Phill
Phill
Thanks Phill,
I think you are being a bit generous describing a few childish sketches as "instructions".
The tiller setup was obviously a no no but as a novice I don't see what is wrong with the shafts, can you explain please?
Scuffing is good advice. I am using cyano to glue wood to plastic & you have to get placement right 1st time 'cause it's not going to budge when it's stuck.
Won't be any further progress today as the weather is perfect for flying! Tata for now.....
The Milliput has arrived. If anyone has not used this product it is well worth getting to know. I even used it at work so up to a few years back if you had seen an AC130H (Hercules gunship) it would have had some of this in it.
The little helicopter ( Blade MSR) is sadly a bit too big for Calypso, it would be a great challenge to land it on the boat.
Neil.
Neil.
MSR is a fun heli, I have the MSRx which is a bit more of a handful
What are the other ones?
Yes the MSRx was a bit too lively for my liking. I had a couple but sold them. The scale jobs are all based on T-Rex 450 mechanics with the obvious mods.
Thanks Phill,
I'm not sure what is included in their kits these days but they used to have a 3mm shaft and plastic props that had little effect i reverse, changing to a 4mm shaft means you can use brass props which are way more effective and you have heaps to choose from.
Phill
Phill
Ah OK, the shafts are now 4mm but the props are still plastic. I'll go with them to start with & maybe change later on.
Interesting that you say they had little effect in reverse as marine propellers are much less efficient when going astern but this can be useful as at low speed the "paddlewheel" effect is enhanced which can be used to advantage when your boat has a single shaft & no bow thruster. On one occasion I used this technique to get around an obstacle & into a tight mooring space. Another boater actually ran up the towpath to ask my crew (wife) "how did he do that?" My hat didn't fit for weeks after.
I'm looking forward to comparing model boating to the real thing although twin screws are a different ball game to what I had.
Thanks for the reply.
An update on the vac-form parts. A couple of elastic bands to stop the wet & dry flapping about in the water made life easier but it is still a pretty tedious job. Don't follow my bright idea of gluing the float halves before sanding as, of course you end up sanding away the contact point so they are back as 2 halves. With the RIB I left the join proud to represent a rubbing strip.
Most of the brass model props are really effective in reverse, I think the main problem I had with the billings props was they distorted under pressure, my diving support vessel with brass props can travel almost as fast in reverse as it does forward, great for stopping in a hurry :-))
I haven't finished my full sized boat just yet but I look forward to trying out your little trick.
Phill
After having boats all my life in my family until just a few years ago I'd love to have a cruiser again.
Sadly it was a family decision to sell the property we had with a landing stage and I don't want to get into paying for moorings etc.
Two family members have narrow boats but it's not my thing.
Getting into the Fairey Marine range of model boats is my fix!
Phill
Interesting, I wouldn't have thought that these props would distort under the sort of pressure I imagine they will be under but I will keep it in mind.
What are you building full size?
I have also sold my boat now & frankly wouldn't want another, not on the Thames anyway. Too many rowers & not enough mooring spaces, not too mention the expense. I'm not familiar with the Fairy Marine range, will check them out.
Neil.
I'm getting a bit frustrated now as I don't have enough information to be able to proceed with confidence. The Haynes manual turned out to be a big help with HMS Victory but the Calypso book is still weeks away apparently. I hope that when it arrives it will be really helpful as my research on-line is not giving me what I need. Any leads on good information such as accurate plans would be very welcome.
Neil.
Calypso started life as an American-built BYMS (minesweeper) for the Royal Navy. You may find information under that heading.
neilesmith,
i have that exact same "calypso" book. I did not buy it for the calypso, but something else, a "part" of the calypso. The book is more of an "artistic" collection than an "accuracy" document. however, it does have a chapter labelled "Anatomy of Calypso" which may help, and of all things, the inside front cover and back cover have a lining that maybe best described as a "plan", with enough info in them that you could probably draft lines for an accurate hull from them.
FYI, I bought it for the illustrations on page 52. luckily for me, i was able to find it used on ebay for $10 plus shipping.
Berkely Engineering mini tug boat :)
(http://i1357.photobucket.com/albums/q760/Phillip_Sachman/DSCF3111_zpsxj9xwzwj.jpg) (http://s1357.photobucket.com/user/Phillip_Sachman/media/DSCF3111_zpsxj9xwzwj.jpg.html)
Yes, thanks I was aware of her history but it hasn't helped much. I even came across a guy who is converting the model back to minesweeper configuration as used by Finland if I remember correctly.
neilesmith,
Sounds a bit disappointing & I have paid £29 & still have to wait weeks for it.
Wow! I just googled them. What a great project, are you documenting the build anywhere? I would love to follow you to completion.
At last I have the book! There is a plan inside the front & back covers, it is a much smaller scale than the model so it's difficult to get really accurate measurements, but it definitely confirms that the forward hull is not tall enough so I will have to work out the best way to build it up.
Meanwhile I have fitted cross beams to maintain the hull shape so the whole superstructure will be removable & started planking the deck.
Vac form can be hateful especially on smaller kits and parts so I salute your perseverence.
A lot of resin kits and small run kits in the lilitary modelling world are just as frustrating. Again, you spend much money on a product you expect to be tip top because the designer/manufacturers want to do better than the plastic it manufacturers but still sell a kit that needs lots of remedial work including not a small amount of scratch building. I bought one kit where despite the designer being a top classscratch builder, he could not make a door and its apeture the same shape! Madness sheer madness.
I look forward to seeing your progress. Stan (See his Schutz build in the Warships section and another fishing boat) has done loads of work to his models that started life as kits.
I appreciate that the manufacturers are cottage industries, but all the same, parts fit should be an important selling point.
Madness is right. If you are going to provide brass frames for the portholes why not laser cut the holes for them the right size? Billing made them all too small which is doubly stupid as the brass part has a lip which would cover an oversized hole.
The base for the crane doesn't fit where the drawing shows it either.
P/M sent having built numerous kits you may find that some parts are better disposed of and remade from sheet plastic. I have found vac form can be very thin in places and this can cause problems when gluing.
Stan.
Hi Niel just a few pictures showing parts from a kit that have been rebuilt using other materials. I find it easier to remake some parts than trying to make them fit.
Stan.
Hi Neil
Just mailed you a link for some drawings, check them out and download them if you can use them.
Br
Carsten
Thanks to everyone who has offered help & advice but my enthusiasm for this project has waned to the point where I have decided to abandon it and concentrate on my many other jobs. When I can find a suitable box to pack it I will be listing on E-Bay. In the mean time if anyone can collect from near High Wycombe for £300 cash they can have the complete kit as started by me plus 2 motors with couplings, 2 battery packs, 1 servo, all new & unused, and the book.
Oh & 2 new waterproof ESC's
ESC: - 2 x HM-50 Waterproof Marine ESC
Coupling(s): - 2 x Perkins (JP5511XX) Cardan + correct size adaptors
Electric Motor(s): - 2 x Mtroniks M500 6.0v - 12.0 + mounts
Rudder Servo: - 1 x Hitec (HS-311) Standard S
