Technical, Techniques, Hints, and Tips => The "Black Arts!" ( Electrics & Electronics ) => Topic started by: foreender on November 12, 2016, 06:39:44 am
my memory switch does not power out when the led lights up,can this be repaired,or is it the recycle bin >>:-(
Is this happening on both switches?
Can you hear the relays clicking?
Jonathan
yes, the relays are working,but no power out.
Dumb question here. Have you got power connected into the relays?
DM
Relays clicking is a good sign - that suggests that the Robbe Duo board is working in relation to being powered and receiving the signal from the RX.
I am sure you know that effectively each "switch" is made up of 2 parts (seperate circuits) - the middle man seperating the 2 electrically but also joining the 2 physiically is the relay.
Can you desribe what you have on the relay side - cable connected from and to, power supplied from , switching lights, sound, pump etc and we maybe able to point to in the right direction as to a fix...
May be a pic would help...
Jonathan
Oops, never thought to check the cartridge fuse, it looked ok, forgot its on a separate circuit.Thanks chaps, red face again Aye, Bill.
Bill,
Pleased you solved the problem
We have all been there at one time or another!
I once went to replace the power supply in a computer - as I came to remove the "dead" item someone had added an "on/off " switch on the back of the case that I swear was never there - a simple click and the "dead" power supply amazingly came back to life.... I am amazed that I did not spot it, how it got switched off in the first place I will never know...
To this day I have the new replacement power supply, never fitted, smiling at me from it's place on a shelf in my den...
Jonathan
