Technical, Techniques, Hints, and Tips => Glue etc. => Topic started by: tizdaz on November 16, 2016, 10:36:11 pm
Hiya guys
Anyone ever used this stuff before: http://www.halfords.com/motoring/paints-body-repair/fillers-preparation/u-pol-glass-fibre-repair-paste-900ml (http://www.halfords.com/motoring/paints-body-repair/fillers-preparation/u-pol-glass-fibre-repair-paste-900ml)
Would it be ideal for fixing wood to grp? I was going to use P40 but i was in halfords amd noticed this one to?
Also ive been recommended that this is the best to use:http://www.mbfg.co.uk/epoxy-resins/sp106-epoxy-resin.html this is what the guy from.Models By Design suggested, the guy whos making my hull so im tempted to go.with this? http://www.mbfg.co.uk/epoxy-resins/sp106-epoxy-resin.html
Exactly the same as P40 m8 I use that and P40 for the repair of cars where it is needed to fill out large dents prior to filler and YES it will do the same job and will do what you want
http://www.halfords.com/motoring/paints-body-repair/fillers-preparation/plastic-padding-glass-fibre-paste
This product also. Many of my recent models held together with this stuff, even pyro fittings bonded in with this muck, much recommended.
Cool thanks guys :-)
That plastic padding looks ideal to, damn theres too many lol!
The guy at Models by Design highly recommended that SP106 stuff and said its what he uses but ive never heard of it, only thing putting me off p40 is ive heard its a nightmare to sand down etc
Just cos you have never heard of it....Models By Design work with Fibreglass products all the time. The product they have recommended has more of an industrial angle to its use, so wouldn't crop up much in hobby circles, but will still be a very good product.
As far as sanding this stuff down, I use a hobby drill with Permagrit sanding drums, usually the coarse ones. Not cheap, but works when you want it to. Once the worst is ground down, you can start on any finer sanding with aluminium oxide papers, starting at about 80 grade, then working down to more usual wet and dry papers. Maybe some filler over the top just to touch up any voids. To each his own I say, but try other people suggestions first. They are usually based on much knowledge gained from much experience.
As a proffesional panel beater sprayer i cartantly would not reccomend any product that would be difficult to rub down Tizdaz
oki doke
Thanks again guys for info great help :)
