Mess Deck: General Section => Model Boating => Topic started by: Glyn Roberts on June 20, 2017, 02:46:51 pm
I have built the 46 inch crash tender, and want to fit 2 Robbe water monitors. I have got the monitors and the pump and now need info how to pro-cede ie how to turn it on /off what battery to use etc. What parts do I need to purchase.
Thanks and regards Glyn
You could use a Micro switch operated by a servo plugged in to your RX, and wire your Pump through the Micro switch to a suitable battery. Other ways are available.
Len.
I have the graupner weser fire boat with working monitors . Fitted a water scoop to keel then used a servo with an extended arm on it to activate a Micro switch as mentioned above . Only addition I did was to program the throw of the servo from my transmitter so it only had to move a few millimetres to activate the pump
Thanks Big Ada and Vts99, Micro switch it is then.
Regards Glyn
