The Shipyard ( Dry Dock ): Builds & Questions => Working Vessels => Topic started by: vk2dj on January 25, 2018, 09:28:18 am
G'day all I have been a member for a while but haven't posted any thing, i have been involved in live steam for a number of years & are currently 6 years in to my current build a Victorian R class 5" gauge live steam loco but am having a brake at the moment ,I was involved in model boats about 35 years ago & after
a holiday to Echuca in Victoria the home of river paddle steamers i decided to build one i have been slowly building a 1/20 scale of the Murray River paddle steamer Adelaide & finally decided to post a few pic of my build,
Not sure weather this is the wright place to post a paddle steamer build but if not please move it to the correct heading
Gary Dapto NSW Australia
1 Frames cut out of hardwood ply
2 planking under way
3 stern planking
4 half way there
5 planks cut out of a 40 year old piece of fine grain Oregon that has been waiting around to be used for something
5 home made steamer out of an old pressure cooker
This is going to be interesting! Looking very promissing so far, keep us updated! :-))
Hi All more pic of Adelaide
1 home made steamer out of an old pressure cooker
2 /3 planking complete
4 a few flaws in the planking nothing that a bit of epoxy will fix
5 set up hull on milling table to drill rudder shaft hole just used what was on hand
6 hull removed from building board
I love paddlers. Have two building a third. Totnes Castle below your post here.
Interesting steamer Hammer, more pic of the Adelaide's build
1-2- starting to fit the deck beams after coating the inside of the hull with Z epoxy
3- Rudder made out of Murray river red gum
4- Deck timbers fitted made out of Tasmanian Oak
5-Rear view showing rudder servo mounting setup ,the rudder is normally controlled by chains but not practical
in the model I will put chains on only for show
Paddlers aren't that popular on this site. Anyone making a plank on frame hull could learn a lot looking at your work. Just about to start on the boiler for Totnes Castle.
Wonderful woodwork!!!!! Just love it!!!! :-)) :-)) :-))
Thanks Danielle I have been following your builds with great interest especially your current build I also like the way you make your frames timber saving
Gary
You have such beautiful timbers to work with Gary. A fellow member from your neck of the woods, Brian B, builds amazing boats from local timbers and likewise they are beautiful. Your rudder alone is gorgeous and the construction is first rate.
It is a shame to paint over the natural colours isn't it!
Yes there are some nice timbers but getting harder to get also expensive,
1-2 bearing blocks made out of 6061 ally machines excellent the bearings are not sealed but intend to fit O rings on final assembly
3- paddle box sides are laser cut out of Birch ply I drew up the CAD file & sent them away to a chap that makes HO scale model buildings they turned out excellent
4 - 5 PB glued together I made them a firm fit to make them removable but I think I will fit small magnets in the corners to make sure they don't come off in use
6 - support timbers on inside of PB the doors are dummy made out of some left over Teak from anther project as they will be hard to see once installed
Gary
Excellent precision in your work a credit to you as a model maker. :-))
I love the paddle boxes! Both sides are really attractive :-))
Regarding timbers, my neighbour at work bought all the yew then availale in Somerset for a Bed he was building for a customer. Admittedly not everyone wnts Yew but it goes to show that some timbers are scarce.
Well English Yew is as rare as hens teeth, takes hundred of years before they mature to seed.
Thanks for the comments as far as timber is concerned we have the same problem out here getting good timber is hard ,I recently salvaged a timber book case that was going to the dump ,made out of Queensland Maple have not been able to get it for decades all you get these days is Murantl
Gary
progress pic on paddle boxes & start on super structure
Are you building so quick or are we catching up with older photos. I hope we are. Yes old furniture is the best way to get timber of any kind. That’s if it’s not chipboard.lol
Yes Hammer I am catching up still a few to go haven't worked on it for the last week as we are having a new kitchen installed this week & have been removing the old one & preparing for the new one hope to be back on it next week , no timber in the old kitchen worth salvaging.
Gary
A few more pic of the build super structure roof fitted , some may notice that there is more freeboard than should be this was done to allow for the weight of the steam engine & boiler
Gary
Awesome carpentry job :-))
Back into the Adelaide's build starting on the wheel house
Pic. 1- wheel house pic. I took the pic at Echuca when on holidays it has not long had a face lift
2- start of the basic structure 1.5mm ply super glued together
3- just to see how it looks on the super structure
4- the roof support post's required the sides to be bevelled so I had to knock up a simple router table
using a Proxxon tool & a small router bit
5- in use bevelling the posts
6- finished post's
Superb woodwork!
I like the selfmade router table!!!! The attachment for the Proxxon drill ... did you make it or can I buy it somewhere?
Hi Danielle I purpose built it just to bevel the edges of the posts & wall cladding it is made up of what ever I could find in the junk box the tilt bracket is from an old TV antenna, the clamp for the Proxxon I machined out of some left over aluminium it did take a few hours to make but makes for a uniform job
Here is a pic of a further modification to the table it is a belt tensioner out of an old ink jet printer the idea is to keep a constant pressure on the timber to get a uniform bevel width works well will post some pic of the end result when I can find them
Gary
I'll try and make one myself .... clever idea with the parts holding down the timber!
A couple of pic of the wheel house progress
Wheel house cladding finished doors fitted & start on roof beams
Gary
Ahah...............very good Gary ....brilliant detail :-))..... I will pop down & see her next week
Will you be finishing the upper woodwork as current limed wood colour painted surfaces, or pre refit as natural unpainted timbers ?
Aw, now this gets better and better Gary! I like the router mounting idea and will look for a swivelly bracket.
