Technical, Techniques, Hints, and Tips => Other Technical Questions... => Topic started by: johnv on July 21, 2018, 10:02:40 pm
Hi has anyone got any pictures of the drive gears on the dickie amphibious vehicle goes well in water but not on land cheers John V
Some info here: http://www.modelboatmayhem.co.uk/forum/index.php?topic=13016.msg124917#msg124917
Cheers for that Martin my one is still on old radio gear goes well in water. Steering ok I think drive gear for road wheels gone i can see it going in bin cheers John V
Hi Martin it's John V just had gear box to bits on my dickie amphibious vehicle and found the small plastic gear that drives wheels had broke in half .The one on the end of the electric motor is brass the one for the propeller is brass .And the most important one is plastic .That's why thay it's. Not driving wheels .That's the fault with them job sorted cheers John V
Here you go John, this is what you fit to a Deans Marine DUKW! :o
(http://modelboatmayhemimages.co.uk/images/2018/07/23/DUKW-05.jpg) (http://modelboatmayhemimages.co.uk/image/Bqdu1)
(http://modelboatmayhemimages.co.uk/images/2018/07/23/DUKW-04.jpg) (http://modelboatmayhemimages.co.uk/image/BqDyu)
(http://modelboatmayhemimages.co.uk/images/2018/07/23/DUKW-03.jpg) (http://modelboatmayhemimages.co.uk/image/BqoRR)
(http://modelboatmayhemimages.co.uk/images/2018/07/23/DUKW-02.jpg) (http://modelboatmayhemimages.co.uk/image/BqVaG)
(http://modelboatmayhemimages.co.uk/images/2018/07/23/DUKW-01.jpg) (http://modelboatmayhemimages.co.uk/image/BqkhZ)
Hi Martin I have built three of them .Don't want to build another.just wanted to find what the fault was with the dickie amphibious vehicle I am getting to clever now cheers John V
Hi John V, my dickie has the same problem, can you show and describe what you did to fix the problem??? also where did you get the parts??
Mark
Hi remove the four screws that hold cover for gear box .Life out axel .take note what way it is remove the four screws.that hold gears .And take note on how that came out .I found it was the small gear that had broke on the electric motor there is a brass gear on the prop there is a brass gear but the one that needs to be brass is plastic drive gear .That's the problem with them .Have you still got the small plastic gear that's broke if you have .Some times you can glue the two halves together useing a good supper glue but you can buy a brass one that holds on to shaft with grub screw but make sure you get the one with the right amount of teeth cheers John V
Hi it's John V againe you can get the small brass gear it's called a motor pinion that hold on with a small grub screw it replaces the plastic one but like I said make sure it has the right amount of teeth and same diameter hole in middle you can get on eBay cheers John V
Hi motor pinion gears from modelsport cheers John V
