The Shipyard ( Dry Dock ): Builds & Questions => Navy - Military - Battleships: => Topic started by: Malcolmbailey on September 12, 2018, 09:12:56 pm
On photographs of the f class destroyer HMS Fortune ( of which I am making a model) is a what I believe is a TDS.
I am struggling to find out how it would work in practice.
Can someone knowledgable on the subject please enlighten me?
Malcolm
Hi Malcolm Do you mean TSDS
Two speed destroyer sweep ?
john
Morning John,
Yes I do!
I thought the T stood for torpedo hence my inability to find anything on the net.
I shall continue my research down the right path now.
Malcolm
From memory there is a description and diagrams of the TSDS in 'The Kellys' ( history of the JKN destroyers)
James
Try Torpedo decoy system?
I understood this to be ...''torpedo deployment"...not sure where the S :o came from ?... Derek
Target Designation System maybe??
A photo of the part in question would help...
Tot Drinking Seaman :D :D :D
Hi All
I have spent half an hour trying to post a photo without success.
One can be seen on the model by JRH of HMS Electra.
Sorry if I am misusing a copyrighted photo.
Malcolm
Hi do you mean one of these?
john
Hi John,
Yes it does look like one of two that would have been towed behind the destroyer.
Does it have a technical name.
Malcolm
Hi Malcolm
It is a Paravane
john
Forgive a RAF crab but isn’t it called a paravane. :-))
I think John just beat me to it! {-)
Thank you gentlemen. Having googled “paravane” the whole purpose and mode of employment immediately becomes clear.
Thanks again
Malcolm
Paravanes are used against mines. A cable would be attached to the Paravane and also to the lower bow. As the ship moves through the water the Paravane would spread outward to make a wide path, as the cables came into contact with the cable that is attached to a mine and it's counter weight it would guide the mine cable outward to the Paravane which as a cutter head that would cut the cable to the mine and make the mine float to the surface so that it could be destroyed by another ship.
Duane
