Technical, Techniques, Hints, and Tips => The "Black Arts!" ( Electrics & Electronics ) => Topic started by: Ghost in the shell on September 20, 2007, 01:04:34 pm
based on some information that has been asked, This is a wiring diagram thread.
Please keep them simple and easy to follow.
2 batteries parrallel with 2x speed controllers using a seperate battery pack to supply Rx
Two Channel setup using seperate battery pack and BEC enabled reciever such as Mtroniks "VIPER" or the Proboat Tornado 50
One Motor, One battery, BEC type ESC supplying power to Rx,
One battery with ESC supplying power to RX, two motors Parrallel wired
Very useful! O0 O0
Can you please do one for a non-BEC ESC (or a mechanical SC), with a BEC-enabled receiver taking it's power from the motor drive battery, powering a single motor?
Unless someone knows better, BEC receivers should not be used above 7.2 volts nominal (6 cell nicad pack). RX makers are happy to put a BEC sticker on the case, but are remarkably shy about just what their built in BEC is capable of. If the main battery is 6 volt, that is what model radios were designed around in the first place (4 dry cells or 3 lead acid cells, both 6 volts, a happy co-incidence), so no extra components are needed. Higher than 6 volts, several manufacturers offer a separate BEC, either kit or ready-built.
Very useful! O0 O0
its identical to the bec type esc, however the red wire isn't pulled from the servo-plug on the esc.
Very useful! O0 O0
Maybe I confused you - the receiver would have no separate battery pack here - it's getting it's power supply from the motor drive battery (because the receiver is BEC enabled).
man in the street, look at reply #2. each part is labled.
Well, the diagram in Reply #6 has an extraneous receiver battery/connection, compared to diagram in Reply #2.
thats because I was using a bec type esc (Mtroniks VIPER 15 for example), when you run this type of esc with a seperate battery for the rx, you must remove the red wire from the servo-plug, hence the red wire being shorter than the other two. a relay or mecanical type esc doesn't feed power to the rx and so needs to have all 3 wires in place as the relays are powered by the rx power source.
