Mess Deck: General Section => Chit-Chat => Topic started by: regiment on September 29, 2018, 05:21:41 pm
sound from tv. free view blasts pictures off wall sky just about hear it new dish and new box from sky nobody seems to know the answer dish and box fitted yesterday problem started today gordon
The skybox has an internal volume,have you used the up/down control for volume on the sky handset??
is this a skybox + and how is it connected to the tv and what sound have you chosen in settings (spanner) sound > Audio>Stereo>Mono>Dolby digital
My Sky handset adjusts the volume on my tv even when the sky button is pressed. how do you increase the sound on the Sky box Brian?
If its sky plus you cant the remote only operates your tv volume on earlier boxes there was a control on the sky box Menu that allowed you to up or down (Balance) the output from the skybox so you did not have a large variance going from tv to sky but that went years back.There is usually one on the tv so its channels can be balanced. The way you connect Sky to the TV can make a difference
Sounds like the Sky connection is not as connected as intended between TV (which is really just a display box) and the Sky receiver. Important to remember that the cable has two ends. Personally, when I worked out that I was paying over £60 per month for less than 3 hours a week on average, I gave up on them.
Thank you kindly for the that jaymac :-))
Hi have you checked the menu settings in your TV? I had trouble listening on headphones until I found the sound on the TV menu was right down, easy to adjust.
Roy
thanks to all who replied to my problem, all fixed sky gave me a new sky box
Sky beat me to it LOL. Dry joints are common in them.
