Technical, Techniques, Hints, and Tips => The "Black Arts!" ( Electrics & Electronics ) => Topic started by: Popeye on November 26, 2018, 10:08:44 pm
Is it possible to reduce the number of turns on my Hitec 725BB sail winch from in excess of five turns to 3 turns?
I'm a Luddite when it comes to anything technical so if there is a way to achieve the desired result could it be explained in 'Idiot Speak'
if you have a computerized radio, setting the endpoint adjustment for that channel will alter the number of rotations for that servo. ie 80% of normal servo throw for that servo of 5 turns would be 4 turns. 60% of 5 turns would be 3 turns...
Or if that isn't an option, fit a "Servomorph" (one of the Action devices, available from Component Shop) between the radio and winch. Set the travel on that to suit your radio.
Or, if such things are available, a smaller diameter drum.
