Technical, Techniques, Hints, and Tips => DC Motors (Brushed) and Speed Controllers => Topic started by: Gardener on January 19, 2019, 08:56:33 am
https://howesmodels.co.uk/product/mfa-540-5-pole-low-noise-6-12-volts/ (https://howesmodels.co.uk/product/mfa-540-5-pole-low-noise-6-12-volts/)
What size Speed viper marine Controller would I need with the above motor ?
Taking the numbers from the link provided -
Operating Voltage: 6-12 Volts
No Load Speed @ 12Volts: 6000RPM
No Load Current @ 12 Volts: 0.17Amps
@ Max Efficiency @12 Volts: 4930RPM
@ Max Efficiency @12 Volts: 1.6Amps
I would say any that are rated for your chosen voltage. They start at 10A, which gives plenty of safety margin, but for a very few quid more, the 15 will do exactly the same job.
I agree with Malcolmfrary, go 15 amp ,with a 10 amp fuse in circuit.
Great will do !
I have been running a Springer on 540, 6V lead acid
15A mtroniks and a 10A fuse for the last 8 years.
In the lake twice a week and at least one rescue each outing. Never even stuttered.
Should say though motor is water-cooled.
She pushes everything from a Club 500 to HMS Hermes at 8ft and heavy
