Technical, Techniques, Hints, and Tips => Radio Equipment => Topic started by: IKB on September 03, 2019, 10:28:35 pm
A while back I converted my F14 TX to be dual frequency with the addition of a Corona 2.4Ghz DIY kit, I detailed the build here:
https://www.modelboatmayhem.co.uk/forum/index.php/topic,52395.msg549580.html#msg549580 (https://www.modelboatmayhem.co.uk/forum/index.php/topic,52395.msg549580.html#msg549580)
This has worked really well until the aerial for the Corona unit broke, does anyone know exactly which screw on black aerial this system uses as I am tired of buying incompatible ones
Alex
Hi Alex,
Post of pic of the antenna socket - likely RP-SMA- is it male or female?
Does it look like this
https://coolcomponents.co.uk/products/antenna-2-4ghz-duck-rp-sma?_pos=3&_sid=cf61d3c05&_ss=r (https://coolcomponents.co.uk/products/antenna-2-4ghz-duck-rp-sma?_pos=3&_sid=cf61d3c05&_ss=r)
C-3PO
if it is anything like their module for the futaba radios (see picture) then you need to get an "RP-SMA" style antenna... like the following:
(the link is for representational purposes only)
https://www.ebay.com/itm/2-pack-RP-SMA-Antenna-for-WiFi-2-4GHz-5Ghz-Wireless-Router-or-Card-2X/141612174353
Hi Guys,
Thanks for the replies, I will have a look after work tonight and see what the socket is like
Alex
Hi Alex
Just read the detail (see below) on the CoolComponents website - this could be a factor in the frustration of getting a correct replacement- however both are available
The FCC is moving towards Part 15 compliance.
All this means is that all the SMA RF connectors are changing gender. Really annoying for those of us who need to mate an antenna to an RF device.
The FCC gender change was instituted to prevent home users from damaging RF equipment (think home WiFi) when screwing on an antenna.
If all antennas are female, there is no way to damage the center connector.
C-3PO
Hi Guys,
So checked the aerial socket and it looks like the Cool Components one for the win, will order one and find out! Can't wait to have my favourite TX back in action
Thanks for the help
Alex
Well I bought the new aerial and it broke on the first outing, not impressed, once I source an alternative I will try again
Alex,
I guess from your comments it was the qulaity of the product at fault and not the user (!)
I have several from Cool Components that have survived some years
Have a look on Amazon...quite a few different ones - this is just an example
https://www.amazon.co.uk/Omni-directional-Antenna-802-11n-Connector-Pigtail/dp/B07FDN82D8/ref=sr_1_1?keywords=2.4+ghz+antenna&qid=1573734504&sr=8-1 (https://www.amazon.co.uk/Omni-directional-Antenna-802-11n-Connector-Pigtail/dp/B07FDN82D8/ref=sr_1_1?keywords=2.4+ghz+antenna&qid=1573734504&sr=8-1)
C-3PO
Hi C-3PO,
Yep, I may be ham fisted but this was a quality issue {-)
Many thanks for the link, I will have a closer look tonight when I have the TX in front of me
Alex
