Technical, Techniques, Hints, and Tips => The "Black Arts!" ( Electrics & Electronics ) => Topic started by: justboatonic on September 13, 2019, 04:03:19 pm
A small resistor has blown on SWMBO hair straighteners (dont ask!). Its a blue body with rings as follows; brown, black, black, black, brown. Anyone tell me what the resistance value is, please?
Thanks.
This might help youhttp://www.ecobionlabs.com/index.php?page=resistor-basics-identification (http://www.ecobionlabs.com/index.php?page=resistor-basics-identification)
I would imagine you need to consider resistor wattage rating as well as resistance value...
http://www.resistor-calculator.com/ (http://www.resistor-calculator.com/)
C-3PO
Ask yourself, 'why has it blown?'
This is a mains appliance presumably
that SWIMBO is holding to her head.
Bin them and buy new I would say.
What he said. These things are usually designed to be assembled once, but to be disassembled and put back together again.
Looking at [size=78%]https://www.allaboutcircuits.com/tools/resistor-color-code-calculator/ (https://www.allaboutcircuits.com/tools/resistor-color-code-calculator/)[/size] - 100 ohms at 1%, no clues as to wattage.
Worked out as brown=1, black, black =0,0, multiplier (number of zeroes), black=0, brown gives a tolerance rating of 1%
Google is really wonderful sometimes.
The resistor 'blew' because the swivel power connection was unsound causing sparking \ power surges. I fixed this connection so this no longer happened and applied a little conductive grease to it. I eventually worked out the resistor is 100 ohms.
