The Shipyard ( Dry Dock ): Builds & Questions => Navy - Military - Battleships: => Topic started by: Chris67 on October 05, 2019, 04:34:46 pm
Hi !
New building from Billing Boats
The Absalon class are support ships of the Royal Danish Navy, commissioned in 2005. The two ships in the class may be described as a hybrid between a frigate and military transport ship with multiple role capabilities, with the capacity to be transformed from a combat ship with the firepower of a traditional frigate to a hospital ship within a day.
Hello !
Two following pictures ........
Hi Chris look forward to following this build :-))
Hey Chris,
How well do the frames fit inside the hull?
HDMS Absalon - on the TV right now. Discovery Science +1 channel :-)
Hi !
To Martin
Frames are laser-cut parts on wooden boards.The reinforcement frame fit perfectly in the hull and must be glued to the hull.
I fitted radio gear to one and the engineering of the kit is most excellent. However the use of self adhesive stickers for things like anchors (!) and grill work leaves something to be desired. However, as a basis for a bit of super detailing, a very good start.
Also, I hear it sails really well, which is a bonus!
Hi unbuiltnautilus !
I agree with you concerning adhesive stickers for things like anchors. For the price of the kit they could have added anchors !
For example, I’ll build her with a bow thruster.
Hi !
2 pictures as follow .....- Model equipped with a bow thruster- Assembly of the 2 parts of the sonar bulb and realization of one of the 2 housing of the anchors. In the kit, the locations of the 2 anchors and nozzle outlets of the bow thruster are made of adhesive stickers.
HI Chris this looks a good build I will be following to see how you get on as im building HMS TIGER in 1/72 scale on here
chris
HI !
Installation of rudders, propeller axle chairs, stern tubes and banana propellers. The propeller axes are slightly offset from the rudders as on the "HMCC Sentinel".
LOOKS FAB
Hi !
One photo ....
Assembly of the superstructure that will fit between the frames and their side reinforcements.
Liking the props
Hi !
Pic 1 : Front assembly and wheelhouse station. Pic 2 : Front radar mast assembly.
Looking good :-))
Hi !
The radar base structure
Hello !
Central and rear radar masts assembly and general view on the superstructure.
Hi !
Installation of the rudder control system. I modified the location and housing of the control servo by moving it a few centimeters back from the stern in order to have access to its disassembly in case of a problem.
Hi !
Deck over hull. Being in one piece in the kit, I cut it into 3 parts: front, middle and rear bridge; easier to install! Then , operations "masting" and "sanding" between the hull-deck joint. On the front deck, one will notice the access hatch to the bow thruster.
Looking Good! :-))
Hi !
Entrance to the helicopter garage.
Good God, that looks frighteningly close to being a kit that fits together perfectly!
The superstructure work looks great Chris :-))
Hi !
Gluing of the front wheelhouse block onto the deck and the side walls onto the hull reinforcements.(Pic1&2)
General view with the embossed superstructure. (Pic3&4)
Hi ! And Happy Easter
Building and installation of the starboard side chimney
1- Port side chimney
2- View of the 2 chimneys on the superstructure
Hello !
Deck: finishing of the main work elements (formwork types) port and starboard along the superstructure.
It's been a while since I last looked in on this one and - Wow, very good work indeed, all nicely put together. Looking forward to seeing more on this one O0
:-)) Thank you ! I've time for building with covid-19 ok2
Hello !
Armament: 5 Stanflex module slots carrying "Harpons" and "Sea Sparrow" missiles. Assembly of 3 vertical "Sea Sparrow" missile firing platform and 2 double "Harpons" anti-ship missile systems.
Those launchers are gorgeous. She's coming along well :-))
Hi !
Assembly of the 2 lifting cranes of the missiles
View of one of the crane at its place
Hi !
Pic 1 : realization of the hardware
Pic 2 and 3 : Filling with mastic the seam between the hull and edge walls
Hi !
Painting HDMS Absalon
Hi !
Finishes: hull and flight deck
Looking superb Chris...... :-)) .........
Hello !
Pic 1 : 127 mm gun, one 35 mm Oerlikon Millennium anti-aircraft gun and 4 Terma decoy systems.
Pic 2 : StanFlex modules with "Harpons" and "Sea Sparrow" missiles
Hi !
Helicopter MH-60R Sea Hawk (Revell 1/100)
Chris67
Coming along nicely :-))
Hi !
2 pontoons under tarpaulin
Hello ,
Just few words: great job.
I'm following your building.
Beautiful workmanship..!
I was impressed with this ship when I saw it on the TV, great scale version you have there.
Best regards
David.
HI Chris yes like the guys have said a great build an very detailed im likeing very much keep up the good work as i'll be following also
chris :-))
Hello !
Ready to sail ...
She's a good looking ship - hope you manage to get some photos of her on the water.
HI Ray !
I will take photos next week at our annual model show
Excellent!
Thanks Chris :-))
Your model is superb!
Hi !
On water ....
Another one
HI Chris Really fanstastic model on the wet stuff looks really real very well done :-))
chris
Well, she certainly looks the business Chris, thanks for posting the pictures. :-))
Hi Chris67;
Congratulations to have come to a successful sailing after a long time building work.!! :-))
The wave and wake generated by the bow and stern look very realistic.!! :-))
Especially,the wave at the bow is superb and I would like you to enjoy a happy sailing on the water. :-)) %%
Kiyo
Hi !
A video on water !
https://vimeo.com/718430633
