Mess Deck: General Section => Chit-Chat => Topic started by: frogman3 on October 30, 2019, 01:01:24 pm
Title: dremel chuck
Post by: frogman3 on October 30, 2019, 01:01:24 pm
HI all has anybody bought a Dremel chuck for their unit as I have an had a bit of trouble with them ?
chris
Title: Re: dremel chuck
Post by: Taranis on October 30, 2019, 01:47:09 pm
Yes
(https://photos.smugmug.com/Boat-bits/i-n533d8J/0/ffdbfac0/X3/2F59A9CA-691E-43D0-A09D-7F9C3B8EE2A1-X3.jpg)
Post by: barriew on October 30, 2019, 02:12:02 pm
Yes - and the adapter to allow it to fit in Proxxon Drill stand! No real problems although I think it may need a clean and oil as the max capacity deems to have reduced. I use to get a 3.2 mm bit in easily, now it requires a bit of force.
Barrie
Post by: frogman3 on October 30, 2019, 02:15:09 pm
HI Andy  when you say yes do you mean that you have had trouble with the chuck ?
chris
Post by: Taranis on October 30, 2019, 02:18:10 pm
No itís just more convenient
Post by: Mark T on October 30, 2019, 04:33:50 pm
I bought a cheap version one and for some reason it kept on falling off when I applied pressure to what I was grinding or sanding. I then bought a genuine Dremmel chuck and that has been fine with no problems at all. I do find that they work best on the flexi drive like in Andy's picture but again I donít know why.
Post by: grendel on October 30, 2019, 04:38:11 pm
I have replaced all my collet chucks for 3 jaw chucks as it makes life a lot easier just make sure you get the correct thread as I believe there are more than one standard size.
Post by: john44 on October 30, 2019, 05:12:35 pm
Yes I have had a chuck on my dremmil for 2 years in constant use, so much better than
having to change collets.I got mine from B&Q
Post by: tsenecal on October 30, 2019, 06:26:42 pm
I have owned one for over a decade.  zero issues, it has literally outlived 3 real dremel tools and one non dremel brand tool.
Post by: Martin [Admin] on October 30, 2019, 06:33:28 pm
I bought a Dremel.... maybe another brand but it was out of balance but didn't realize at first.
Eventually  bought a replacement chuck... totally smooth after that!   >:-o
Post by: frogman3 on October 30, 2019, 07:40:58 pm
Well thanks for your views guys an it looks like I have been just  unlucky then >>:-( <*< see what happens when the nxt one comes as ordered one off ebay
chris
Post by: grendel on October 30, 2019, 07:48:09 pm
i have even had out of balance collets, so much nicer when you get a balanced chuck
Post by: frogman3 on October 30, 2019, 07:58:28 pm
HI Grendal is yours a Dremel chuck then ?
chris
Post by: grendel on October 30, 2019, 08:24:51 pm
i think at least one i bought was a dremel but i have got others too
Post by: frogman3 on October 30, 2019, 08:58:42 pm
WELL both mine jammed an they was dremele must have been a bad batch then
chris
Post by: Taranis on October 30, 2019, 09:00:15 pm
I much prefer my Proxxon  8)
https://youtu.be/FclCj7fuJ64 (https://youtu.be/FclCj7fuJ64)
Post by: frogman3 on October 30, 2019, 09:31:28 pm
Cheers Andy for showin me that utube pic im a little bit wiser now  :-))
chris
Post by: frogman3 on November 01, 2019, 11:09:12 am
HI all well my third chuck turned up an the jaws  don't work an also the chuck wont fit my dremmell thread  from the uk here an someone said some have different threads  at the time I ordered these chucks I dint know about that  but now got no.4 & 5 comin from china as they cheapies see what happen to them
chris
Post by: grendel on November 01, 2019, 01:21:30 pm
I seem to recall having one that didnt fit my particular collection of dremels at the time, worst comes to worse you can fit the chuck then using a round rattail file run the drill over the file, slowly shutting the jaws, this should at least true up the jaws. I had to do this on the chuck of one drill as i was using 0.7mm drill bits and the out of balance was enough to break the drills.
Post by: Pete C on November 07, 2019, 07:28:05 pm
Ive gone through two dremmel chucks, The first locked up and the only way to use it was knock it after loosening up, the second just plain dropped apart.. Now on my third and I dont consider me a rough user
Post by: frogman3 on November 07, 2019, 09:32:05 pm
HI Pete these chucks are not very good an im very diappointed in them  >>:-( <*< ive had three now an rubbish I think  ive got two more on the way on a slow boat from china see if they will work ok
chris
Post by: Taranis on November 07, 2019, 10:08:47 pm
This is the type I bought and not been a problem
https://www.ebay.co.uk/itm/Multi-Chuck-Quick-Change-Adapter-Drill-Bit-For-Dremel-Rotary-Accessories-Kit-M7/152567763855?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D20131003132420%26meid%3D62647e83e9424d41a0db214c1e804336%26pid%3D100005%26rk%3D2%26rkt%3D12%26mehot%3Dag%26sd%3D263449229438%26itm%3D152567763855%26pmt%3D1%26noa%3D0%26pg%3D2047675&_trksid=p2047675.c100005.m1851
Post by: frogman3 on November 08, 2019, 10:19:39 am
https://www.ebay.co.uk/itm/Multi-Chuck-Quick-Change-Adapter-Drill-Bit-For-Dremel-Rotary-Accessories-Kit-M7/152567763855?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D20131003132420%26meid%3D62647e83e9424d41a0db214c1e804336%26pid%3D100005%26rk%3D2%26rkt%3D12%26mehot%3Dag%26sd%3D263449229438%26itm%3D152567763855%26pmt%3D1%26noa%3D0%26pg%3D2047675&_trksid=p2047675.c100005.m1851 (https://www.ebay.co.uk/itm/Multi-Chuck-Quick-Change-Adapter-Drill-Bit-For-Dremel-Rotary-Accessories-Kit-M7/152567763855?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D20131003132420%26meid%3D62647e83e9424d41a0db214c1e804336%26pid%3D100005%26rk%3D2%26rkt%3D12%26mehot%3Dag%26sd%3D263449229438%26itm%3D152567763855%26pmt%3D1%26noa%3D0%26pg%3D2047675&_trksid=p2047675.c100005.m1851)
HI Andy thanks for your reply  on this Dremel chuck an you say yours is ok that's good  well id love one but the last 3 I bought the jaws did not work an jammed an the last one the chuck dint fit my Dremel thread so no good again so I don't know what to do ?
chris
Post by: Pete C on November 08, 2019, 10:50:16 am
chris
Just oredered a couple to see if they are any better than the poor (my opinion) dremmel provided chucks...
Post by: Andyn on November 08, 2019, 01:19:54 pm
It's odd, at work we have about 15-20 Dremels that are quite a few years old, mainly 8200's, all with the Dremel official drill style chuck on them, no issues at all and these things get ABUSED. Recently we ordered four new 8220's for new starters, along with the chucks to go with them. Two of them would not fit at all, even on existing 8200's. Seems their manufacturing has changed.
Having said that, if you've managed to break one of the old style chucks then I don't know what to tell you...
Post by: frogman3 on November 08, 2019, 02:08:57 pm
HI Pete so you have had probs with Dremel chucks as well as me I thought it was just my luck when you get your chucks could you tell me if they are any good please ?
chris
Post by: frogman3 on November 08, 2019, 02:11:56 pm
HI Andy no ive not managed to break the chuck as all 3 of them never worked in the first place jaws were jammed I even tried a little wd 40 in them but no go
chris
Post by: frogman3 on November 12, 2019, 09:15:07 am
HI Pete have you by any chance got your new chucks yet ? an if you have do they work ok ?
chris
Post by: Pete C on November 16, 2019, 11:34:44 am
Well Ordered the chucks from ebay and it turns out that most on ebay are 7mmx.075 thread (WRONG TYPE ) which I bought.
The correct thread for my dremel and Parkside rotary tools after checking with dremel are 8mm x .075 thread.
Most of the keyless chucks that are listed on ebay are 7mm x.075 thread ...  which is what I purchase (x3) but I somehow got 1 correct chuck in the 3 I orderd
A fluke ! so I have 2 chucks with the 7mm thread and 1 chuck with 8mm thread (the correct one).
So if you people got to ebay like most of us do double check your ordering the 8mmx.075 thread or like me you will end up with a few duff chucks that I have now idea what tool they will fit...
I have noticed on ebay that if you search for 8mm  keyless chuck in rotary tools most the pop up cheap are the short type... so I will now order two short type and two  long type (slightly more chas folks) in the correct thread (8mm x.075mm -- confirmed by dremel)
Post by: frogman3 on November 16, 2019, 02:10:10 pm
HI Pete many thanks for the info an the pm 's an I have now got to buy a new Dremel as my old one died yesterday >>:-( <*< so im gonna have a good look round an for a chuck that will fit it so far if I buy one tomorrow when im in Norwich it will be no.6
chris
Post by: Mark T on November 17, 2019, 02:19:00 pm
Pop into B&Q they keep dremels in stock including spare chucks and all of the accessories
Post by: frogman3 on November 17, 2019, 03:24:07 pm
HI Mark that's what I did this morn an I bought a new Dremel 3000 multi speed an I actualy managed to buy a chuck that fitted the new Dremel an this one works the jaws open an close nicely  :-)) im amazed
chris
