The Shipyard ( Dry Dock ): Builds & Questions => Lifeboats => Topic started by: bobgrimward on November 04, 2019, 07:05:24 pm
I wonder if anyone can help.
I have managed to obtain a partly started Speedline kit. The only problem I can see is a bow thruster tube has been fitted with out any motor or impeller.
I was hoping to purchase another so I did not have to remove the tube but I can not find one. It is approx 35mm diameter made from aluminium with a over hole cut in the top which I presume is where the motor and impellor go.
Has anyone come across this type of bow thruster before and if you know who the manufacture is.
Many thanks.
The kit used to come with the raebosch
Bow thruster with propellers I would check that unit with what you have
