The Shipyard ( Dry Dock ): Builds & Questions => Working Vessels => Topic started by: Pete C on November 22, 2019, 04:14:51 pm
Well Just bought 2 of these from Sarik hobbies, so will see how the build goes, ots of styrene work ....
any build advice and pointers welcome
Interested how you get on. There's build info and pics back to the original article on Google. 2 were pictured by someone here on the new carrier sea trials entering harbour.
I have a hull but made a bad start so far. Also I thought I bought 555 motors but think they might be the rubbish 550's in the end. Unfortunately for the original designer, pics of the plans are on-line enough to make a start and check allot of crude dimensions. Personally I think the hull is out at the transom. Think my moulding is "v" shaped when it should be curved across the beam? I have a feeling the beam is out a bit also, but that could be usual "spring back" after vac moulding.
Not sure if that helps,
Website: https://www.sarikhobbies.com/product/pilot-40-pack-hulmm1444/
Yes I think the vacformed hull is off a bit and also it looks the master has had a repair done and not faired up very well, so we'll see how it goes.
Im installing a couple of brushless motors in 1000kk I think.
I have the shafts made now and the rudders are ready, will need a good think about the keel as with the plug bing out a bit I'll have to play most of it by eye.
willl post pictures once I have the keel in and propshafts.
My son now has the second hull and I think he is useing it to freelance a model pilot he likes so I dont think the errors will be too bad for him to deal with.
