The Shipyard ( Dry Dock ): Builds & Questions => Springer Tugs => Topic started by: dave parker on January 17, 2020, 08:20:54 pm
i have just cut out my springer hull prices from 6mm plywood and have got a lot of tear out and chipping along the edges, only on the top side though
I think I may have the wrong jigsaw blade
Is this a common thing?
Obviously it can be fixed later when sanding and filling the hull for paint
Any suggestions?
A finer blade with a slower feeding of the work piece into the blade,
Running a sharp blade along the intended cut line, then sawing away from the line and sanding to it.
Put masking tape over the cut on the pull side of the blade. If the line isn't visible enough when cutting re-trace it. You'll almost always have an "edge" when cutting.
Reverse the sides so the decent sides are on the inside. It's common, especially if the ply is a tad old. :-))
I usually use a hacksaw blade in a jigsaw when cutting plywood. It gives a better cut.
Thanks Tony, that’s a good idea, then prep he outside before paint
Thanks Colin, sounds interesting. Do you cut the blades in half before fitting in to jigsaw?
I use jigsaw hacksaw blades. The fine toothed ones.
With dodgy wood I cut outside the line and sand back to where I need to be.
Chas
There are special jigsaw blades for cutting plywood.
They have a higher number of teeth per inch (TPI), and they have a slimmer blade to make cutting curves easier.
They are not expensive.
If you use masking tape, the blue stuff has a glue that should not leave a residue.
Hi Guys
I use Makita double cut blades which a cut like a planner blade.
Two numbers on the packet No.10S and A-85824.
My Makita is an old one, but they have blades for the newer ones.
TOTALLY RECOMMEND THEM !!!!!
All my old wood cutting blades are in the rubbish bin.
CANABUS
