The Shipyard ( Dry Dock ): Builds & Questions => Working Vessels => Topic started by: portside II on February 05, 2020, 08:46:03 pm
Just aquired a unfinished/ just started Brakengarth, basicly the running gear is fitted and some of the stucture work started.But this one came with a full fitting kit, lots of bags of white metal, so if its there i will attempt to fit it :embarrassed: .Its going to take me a while to get it ready for the water but i think it will be worth it.daz
Nice one daz. It would be good to see a progress log on here if you fancy doing one :-)
Yes it might not be up to our Martins standard , but i can do photos.daz
A couple of pics to start with, not the best of quality as my phone is in for repair and the standby one is so primitive.I found my spare Marx Ludder bow thruster and drilled the hole for that and the blank tube , i think it looks better with duel thrusters even if one is just a dummy.Final fitting will be done when i get some body filler.daz
Hi Bonny lad,
looking good are you going to add some colour to break a habit of a lifetime like more then three lol hope you and the good lady are well. hope to see you two soon.
Regards Howard.
Whell it won't be a rainbow warrier , although it mat obstruct a few rag flapper's on the pond.Yes we keeping well and looking forward to the good weather. Dont forget if your free its the hobbies exhibition at the leisure center in Goole on the 21st of March, allways find time for a cupper and a chat.daz
update putting together some fittings.daz
fittings
that was a gang valve i believe.these are mushroom vents.
fittings with coat of primer ready for top coat of red.
