The Shipyard ( Dry Dock ): Builds & Questions => Working Vessels => Topic started by: leachim on March 25, 2020, 06:08:38 pm
A year ago for my birthday, my dear wife bought me a kit to "Keep yourself busy". I had just finished making a Springer tug, that is still awaiting a maiden voyage, and needed something else to do. I have tried to take photos as I built the thing and some notes on how I got on along with comments on the kit and how easy or otherwise I found it. I will be posting on this thread over the next few days.
Ulyses is a plank on frame kit made by Occre (Occio Creativo) from Italy and comes delightfully packaged with laser cut ply panels, bundles of wood strips and lengths of dowel. Also included are two lovely sectioned clear plastic trays full of goodies including white metal castings for portholes, anchors, ventilators, tyre fenders etc. some brass strip and rod cotton thread and some fabric. The kit includes a brass rudder with plastic stern tube and a propshaft with a twin bladed plastic prop.
There is an instruction booklet with parts list showing the items on each laser cut ply sheet. instructions giving build steps supported by a booklet of colour pictures annotated with part numbers. The photos proved extremely helpful especially when trying to work out what the white metal castings were as they were not described in the instructions.
Forgot to mention last time that there were also full size plans with the kit with some very useful dimensions on.
Well first job was to look at the parts layout and mark all the part numbers on the laser cut ply bits. The Mowe 2 that I made with my grandson had the part numbers laser etched into them but not so with the Occre kit.
All marked up, the next job was to find a building board. Didnt have anything at home so a quick trip to the DIY store where I picked up a cheap pine shelf which was perfect for the job.
Releasing the laser cut ribs from their ply sheet was a bit of a chore but a sharp scalpel made short work of the retaining tabs and very soon I had a small pile of boat parts. I used some plastic corner joiners that I have had for years as support blocks to keep the false keel upright and with a small engineers square set to glueing the ribs in place with a fast setting wood glue. It rapidly began to look boat shaped. All the parts needed a little fettling to make them go together, all the little nibs where the parts were retained in their ply sheet needed removing and some, not all, of the slots needed easing. However all went together surprisingly well and quite quickly. This was going to be a fast build, or so I thought!
With my support blocks repositioned onto a couple of battens the hull could be flipped over and fully supported ready for the planking. Now the instructions say sand the edges of the ribs to achieve a good contact surface for the planking (or lining strakes as they call them). what isn't made very clear is how much needs to be sanded off the bow section of the false keel. The photos don't help much in this ares either. so assuming the keel strips, that are added much later in the build, need to glue to a flat area I sanded the bow of the false keel to leave a flat area the same width as the thickness of the keel plywood. If I built this again I think I would sand down to a point and then sand the planking back to form the contact area for the keel as I have been left with a bit of a step between the planking and the keel at the bow. However it doesn't really notice on the finished boat so I am reasonably happy with the result of my labours.
There were plenty of planks in the kit, so many that I'm pretty sure I could plank the boat again with the leftovers. The first plank was placed at the top of the boat near deck level making sure that 3mm was left for the bulwarks to fit, it's all in the instructions, first one side then the other. I'm glad I invested in a pin pusher as there is no way I would have coped holding the plsnks in place while trying to hammer the pins home. A combination of fast setting wood glue and thick cyanoacrylatewas used to fix the planks in place. Working from deck to keel and from keel to deck the planking progressed, slow but steady. I'm pretty sure that I didn't trim the planks correctly and am certain that I didn't take enough care sitting the planks down on the frames and butting them up to each other. When finished there were more areas where the edges of the planks stuck out more than I would have liked where the curve of one plank hadn't quite matched the bend in the next resulting in more filling and sanding than was strictly necessary. I also fell down on the photo front and can find no pictures of planking progress, only the finished thing. How long did this take? Far longer than it should because I got a little bored with the process and allowed the summer to get in the way so progress was halted for a few months. Anyway once I got back to it eventually the grind of planking was over and I had a reasonable looking hull on my bench.
That looks like a very nice kit your dear wife got you there. Lovely work so far!
I love tugs!
Dom
I have to agree that is really lovely work and it looks like a nice tug too - I'll be watching your updates good luck with your build
With the outside of the hull planked there was a lot of filling and sanding to do. I give thanks to the "Mouse" sander that I acquired it was just the job and saved hours of scratching with sandpaper. Not the most exciting job in the modelling world and I'm afraid I set it aside more than once to do something more interesting.
I thought I'd make the funnel. The kit comes with a nice carboard tube for the funnel with three lasercut ply flanges to fit at the top, partway down and at the bottom. This is when I found my first major problem with the kit. The cardboard tube that I wasn't exstatic about as it looked like it would cause me problems with finishing was too small to fit the ply flanges! It wasn't a fraction too small but significantly lacking in diameter the photo below shows the difference. Luck was on my side though as I found a length of wastepipe that was the correct diameter so consigned the card tube to the bin. Completely out of sequence, making the funnel felt like a major step forward. With the flanges glued up and the funnel painted it was set to one side until it was needed.
Next step with the hull were deck plates ready for planking the deck with some lovely mahogany strips. The instructions state to glue the planks to the deck sheets then draw in the joints with a pencil. I had read somewhere that using a black sharpie on the edge of the wood strips works well so I did a small test and was pleased with the result. So each plank before being glued down was marked along the edge with a sharpie then cut to length, positioned and glued in place using thick cyanoacrilate. I challenge anyone to do this without getting stripy black glue encrusted fingers! Still the deck looked ok in the end, and the glue does eventually scrape off the fingers.
Realistically, your hull planking work is a job well done :-)) as the underwater shape appears true and attractive [for the period]
One could say this is only governed by the frame profiles, however I disagree as the natural curve & flow of the individual planks also plays a very important part
Before completing the decking, you may wish to consider how, and your chosen method of waterproofing the hull internals, together with the installation of the mounting rails or frames supporting the boiler, engine & propeller shaft tube etc etc
Finally, the photographic image shown on the box top could suggest the top Black section of the funnel is smaller than the White & Blue lower sections.....so this would explain the [telescopic looking] differences in funnel section diameters?! %)
An interesting thread....thanks for sharing & keep up the good work
- Thanks!
- I agree, the plank curvature between the frames produced the lovely hull profile. The only problem I had was some planks curved more readily than others. Some were nicely curved wheras others seemed to want to stay straight. Easily sorted with a little filler but unnecessary work If I had been aware of the problem whilst planking I probably would have taken more time to provide smoother curves on all the planks.
- Had decided very early on that, having no experiance with steam, I would rely on electric power for the tug with a steam effect.
- The funnel is the same diameter all down on the plans. The problem I had was the ply rings internal diameter was much larger than the diameter of the card tube so there was no way of glueing them in position without increasing the tube diameter in some way. The photograph shows the card tube sitting on top of my plastic tube funnel.
Whilst working on the hull and deck planking my mind turned to motive power. I had made a decision quite early on that I wasn't goint to fit a steam plant. I have no experiance of steam and didn't want to complicate a build that was already taxing my skills, after all it's my first plank on frame build! However I rather wanted to have the ship looking like it was steaming so I would need something to make steam come out of the funnel. On this forum is a very interesting thread on how to make a cheap steamer, I had a good read and turned to the internet to see what I could find. There were plenty of 12 volt ultrasonic humidifier units but I was really hoping that I could use one of my 6 volt battery packs to run the thing. I found a nice small ultrasonic 'donut' humidifier designed to float in a glass of water, this seemed ideal so I placed one on order. It came complete with a USB plug. Now I didn't want to cut the wiring so needed an USB power source so back to t'internet. There were several electronic circuitboards that would reduce voltages down to 5volts. I found one that would take 12 - 4 V input and out put 5V via two USB sockets at a very reasonable cost, needless to say I ordered one then say and waited for China to deliver.
When the parts arrived I quickly cobbled together a test rig to see if it would work. The humidifier floated nicely in a tumbler of water, with the circuit board connected to a battery pack and the USB plug connected, the humidifier sent out a very satisfying stream of "steam". Blocking off the outlet with a piece of ply I placed the Funnel on the top and watched the steam come out. It needed something to push the water vapour out, a fan was needed. I found online a computer fan with a USB plug and so a plan came together. Using a plastic pot with a screw lid (it used to hold treasury tags) I cut holes in the lid and mounted a length of tube that would fit easily inside the funnel and the fan to the top, fed the wire through and sat the donut humidifier inside the pot. I added a length of silicone tube for ease of filling and screwed the top on. Part filled the pot with water and plugged it in and it worked a treat! The fan was to fast and dispersed the stream of water droplets way to quickly so I fitted a variable resistor in line and turned the fan speed down. Perfect, I could now control the level of steam by controling the fan speed but have no control over the quantity of 'steam' produced. I think it looks ok but wont really know until I get the boat on the water. Overall I am very satisfied with the result.
Photos show humidifier package, first test, the steamer unit complete and a test in the almost completed boat.
Nicely done!The humidifier packaging looks like something out of the sixties or seventies {-)
Dom
Nice build Mike :-))
Len.
I should backstep here to before fitting the deck plates. The instructions suggest sealing the interior with varnish to help strengthen and waterproof the inside while you can still get in there. I had some Poly-C left from my Springer build and several coats later I had a nice waterproof hull, well inside anyway. Then on went the deck plates and deck planking.
With the deck finished the next step was to fit the bulwarks, 4 nice flexible pieces of laser cut ply two per side. I had expected to have to greatly trim these with the possible inaccuracy of the planking but was surprised how well the fitted. Just a small adjustment and they went together very nicely. a mixture of woodglue and cyano along with many clamps and the things were set in place. The instructions suggest painting the insides before fitting, I prefer not to try gluing paint so left them unpainted, yes I knew this would give me some possible problems when painting.
Next came the keel, this was in three sections again laser cut ply. Slight adjustment needed to match the curve of the bow and a decision needed with regard to the length of the keel extension under the rudder, easily sorted with reference to the plans. with bulwarks and keel fitted I had to finally get on with finishing the filling and rubbing down and sealing of the hull planking. I had decided that I would apply a fine fibreglass mat to the exterior to add strength and ease finishing (I had done this to my springer Poly-C and lightweight glassfibre cloth but that was nice and flat, Ulyses curved hull would be more of a challenge). It's always a little worrying as to how to prevent wrinkling but somehow the glassfibre went on nice and smoothly with no major wrinkles. Poly-C fairly odourless, quick drying and water based I found to be very user friendly and was very happy with the result. Once all was dry and set trim back the cloth and apply several more coats of Poly-C to fill the grain in the cloth ready for paint finishing.
Fairly early on in the construction of the hull you have to glue in a plate to support the motor. I had done this but needed to decide fairly quickly what motor I needed to drive the ship. I did a lot of reading through threads on this forum and came away almost as confused as I was before I started. There were so many motor / prop combinations and everyone seemed to have their own idea as to what was best. I had to start somewhere so took a decision. I am rather old school and brushless motors are beyond my understanding so a brushed motor it had to be. I ordered a MFA 540/1 motor complete with stand and an Mtronics Viper marine 15 ESC to run it.
The kit came complete with prop tube, two bearings to be press fitted into the ends and a 4mm propshaft. This is where I found my second problem with the kit. The bearings were pressed home, took a little effort but we got there, and the shaft slid in nicely. I fitted the two blade plastic prop that had been supplied and gently rotated it. The shaft turned nicely then stiffened before turning freely again. It was binding somehow. I blamed my insertion of the bearings as I couldn't see anything wrong with the shaft. Muttering under my breath I placed an order for a prop tube and shaft to replace those in the kit and was very pleased when it arrived all ok. Out of interest I tried the new shaft in the old tube and it rotated freely! there wasn't anything wrong with the prop tube in the kit but something definitely wrong with the shaft which has now been consigned to the bits bin. With the prop fitted and breath held I carefully drilled the clearance hole needed to fit the prop tube. It wasn't as difficult as I feared and I was able to slide the tube home ready for glueing.
There are loads of comments regarding motor / shaft alignment, this needed to be my next priority. The propshaft seemed to be pretty much in line with the motor shaft when I sat the motor on its stand in the bottom of the boat. I needed an alignment jig. Two pieces of brass tube slid together 4mm i/d at one end drilled out to 3.2mm the other and I had a method of keeping the propshaft in line with the motor. So with the motor temporarily fixed in place and plenty of two part epoxy glue on the prop tube it was set aside to go off. 24hrs later all was hard and looking good. The shaft was removed along with the motor and placed to one side so I could paint the hull.
Woah! I had forgotten the rudder tube. Taking my life in my hands again I carefully drilled a vertical hole for the rudder tube, all done by eye bus with the assistance of an slot in the framework indicating the rudder location. That done the plastic rudder tube was fitted and glued in place. It needed a little adjustment to allow the moulded flange at the bottom of the tube to fit against the sloping rear of the hull but I achieved it and made certain there was plenty of epoxy sealing it to the hull.
Then out to the shed for some coats of Halfords filler primer to see wher we were hull shapewise. Several coats of paint, rubbing back, filling, rubbing back, more paint ensued until I was reasonably happy with the hull. Photo shows that I had progressed the superstructure as well but I will talk about that next time.
Several coats of paint, rubbing back, filling, rubbing back, more paint ensued until I was reasonably happy with the hull. Photos show that I had progressed the superstructure as well but I will talk about that next time.
The superstructure, there are two main parts to this build. The wheelhouse/cabin and rear hatch covers (for want of a better description). The cabin constructed from lasercut ply panels which went together well once the little nibs are rubbed off with all the panels glued with a waterproof woodglue. Usual proceedure of sealing the wood prior to painting. The floor and walls of the cabin are lined with African Walnut, nice wood strips supplied in the kit. Two shelves and a line of coathooks added to the rear wall a bench seat and table to one side. A 'shelf unit' that supports the binnacle, control panel, levers and wheel made from two lasercut ply panels fits to the front of the cabin and the walls are then panelled as the rear. The windows are framed with walnut strips, very fiddly but looking great once done. I glazed the windows with some clear plastic sheet (acetate? maybe, collected from packaging over the years) getting the door to stay in place was a nuisence but eventually the glue went off and it stayed in place, slightly open looking like it's in use. I didn't glue the roof on as I wanted to fit working lights. The kit provides cast white metal lamps and two small dome shapes that took an age to decide where they went. Finally I worked out that they were supposed to be the cabin lights, I didn't use any of these a instead opting for LED lights. I will discuss the lights later.
The rear Hatch covers were cast white metal and quite heavy. I used them but for weight saving probably should have replaced them with scratch built panels that would have been much lighter. The covers fit into a wooden structure, lasercut ply again, looking rather like a small greenhouse. It fits on the rear deck over the aperture giving access to the motor and drive coupling. There is a further box that fills a hole in the deck over the drive coupling where it connects to the prop shaft. This box looks like a fish tray and would appear to be for containment of the tow ropes.
With the ply boxes glued, sealed and filled I painted them using matt white and matt mid grey Humbrol enamel. The colour scheme on the box lid which I quite liked.
It was a relief when they fitted in place with no problems, no adjustment necessary so I must have done something right. Along with these items I also added the capstain, a nicely turned piece of dowel whic I painted Gunmetal grey and black and a square patch of grid made from pre cut strips of wood that locked into each other very nicely making a large rectangle of grid from which two squares are required. One for behind the capstain the other on the cabin floor by the wheel. To finish things off I coloured some tissue yellow and roughly formed two oilskins to hang on the cabin coathooks. I also took the opportunity to cut down a 1:25 scale rail passenger that I had in stock, reducing him to 1:30 to match the scale of the boat and adjusting his arms to hold the wheel. Suitably painted, Fred now steers the ship.
Lights - ah yes the lights now there's a tale. I had decided very early on that this ship was going to have working lights. I have built boats before, a Graupner Elke fishing boat and a paddle tug loosely based on Director class RMAS Favourite (built a long time ago now but still working nicely) more recently Mowe 2 fishing boat with my grandson and my brand new Springer. But I have not put working lights on any of them. Searching the internet I found and ordered a set of steam tug LED lamps from Mobile Marine Models that came complete with brass lamps and resistors. I didn't want to play around with grain of wheat bulbs as they can fail and would be a right pain to replace.
I was well impressed with the lamp set and set about fabricating the navigating lamp boards painting them up ready for the LED's. Two tiny holes in the base of the boards and through the cabin roof to take the LED's 'legs' which were bent at right angles on the underside of the roof and wired together. The wires were run down through a length of plastic tube in one corner of the cabin ending up at a resistor bank and switch board mounted in the void behind the wheelhouse. All wires therefore would stay in the removable superstructure, there would be no need for electrical connections between the superstructure and the hull making life simpler all round. The downside of this is no remote switching of the lights.
Ulyses has two searchlights on the roof, these arrive in the form of two white metal castings which would need to be replaced in the event that I wanted them to work which I did. I couldn't find a commercially available light that looked enough like the ones supplied with the kit so gave it some thought. I had some vinyl endcaps that were used for finishing off the ends of kite spars. Two 8mm endcaps looked just right. I melted two small holes through the bottom and threaded the LED legs through, soldered a length of thin wire to each insulated them and threaded them down a short length of plastic pipe when all was glued in place they looked passable as searchlights. I wanted cabin lighting but decided that white would be to bright so ordered some 3mm yellow LED's to light the cabin. I cut a false ceiling from thin ply and mounted two LEDs through, connecting them together and running the wires with the others down to the switch panel. Power is supplied from a 4 x AAA battery pack fixed to the underside of the cab.
Switched on and all worked happily so I glued the false ceiling in place and attached the roof to the wheelhouse. Turned on and nothing worked. Broke the glue joints on the roof, removed the false ceiling and all worked again. couldn't understand it until I noticed that the bare legs from the cabin lights were shorting some bare wiring from the searchlights. A couple of strips of insulating tape later reassembled and all worked ......apart from the red navigation lamp. It made no sense, it worked before and wasn't shorted out. I had to take it all apart again to find that one of the red LED legs had broken right at the base so the break was hidden by the thickness of the roof. Replaced the LED with a new one and all was hunky dory.
Next thing to attack - the mast lights which, as all storytellers say, I will tell you all about another time.
Although the mast isn't due to be fitted yet, according to the build instructions, I wanted to sort out the lighting. the lighting kit I bought included 4 white, 1 yellow, 1 red & 1 green LED. along with instructions thin flexible wire and resistors. I cut the dowel for the mast to the correct length and fabricated the platforms for the lamps to sit on. I did a lot of research and became very confused as to what lights the ship should show. Red and green navigation lamps were straightforward, the mast lamps not so. The lighting kit showed three white lamps on the mast along with an alround white anchor lamp, with a yellow lamp rear facing on the mast and a white stern lamp. The picture on the box seemed to agree with this but doesn't show a stern light anywhere. I decided that I would concentrate on the mast and fit 3 working lights facing forward, one yellow one facing rearwards and worry about the stern light later. Using a 1/16" chisel that I have had in my toolbox for years Iscraped a groove on either side of the mast. This allowed me to set in feed and return wires for the LED's. I set the white LED's on their respective platforms positive leg to one side, negative leg the other and soldered them up. with resistor in line I attached a battery and all lit up beautifully. I added the yellow lamp facing aft wired to the same circuit as the white ones and the yellow one lit up but the white ones didn't. A quick message on Mayhem and the reason was explained. The yellow LED needed less current to run and as I was already running three LED's from it it was maxed out and would only supply enough to run the yellow. So I had to enlarge the groove on the positive side of the mast, unsolder the yellow LED from the positive feed and run a separate positive wire for the yellow from it's own resistor using a common negative. At last all worked nicely. So with a resistor board made up for the mast with a switch on the positive side wired to another 4 x AAA battery pack. All this would be fitted in the hull once it was finished and painted. Thanks to all Mayhemmers who helped me sort this out.
The rear facing white stern lamp I placed on the rear of the superstructure just above the towing hook, moving the rear lifting davit for towhook operation slightly more forward than shown on the instructions. It works and looks ok to me.
To operate the lights I now can switch on cabin, navigation, searchlights, stern lights indipendantly but not remotely. The mast lights are on a single switch mounted in the hull near the mast, again not remotely operated. With the room lights off the boat looks fine as I think the photos of the nearly finished tug show.
The hull was changing colour. Starting with Halfords filler primer, mustard yellow, several coats with a very light coat of red primer to show up the defects. Rub back, fill, rub back, more paint etc. etc. Finally the surface looked reasonable, it was never going to be perfect. The hull then went red, Halfords red oxide primer. Two or three good coats with a very light rub back in between, then a good couple of days to harden off. While the paint was hardening I was sorting out the lights and painting all the bits and pieces that would need to be added to finish the boat off.
Sitting the hull in its cradle I marked the waterline. Taking a measurement from the bottom of the hull to the waterline from the plans and adding on the height of the cradle I cut a wooden block to a height that with a pencil taped to the top would mark the waterline onto the hull in the correct place. Then holding the hull firmly I marked all round with a soft pencil then, using a good quality masking tape, I masked below the line. With matt black Humbrol enamel hand I painted the upper section up to the join line with the bulwarks. Yes I know I could have bought some black paint in a rattle can and sprayed it but I had the enamel to hand........
Following the glue joint between hull and bulwarks with a brush was easy so no masking involved. The bulwarks were painted matt white.
With the tape removed the tug was looking more tug like. The superstructure was filled and hand painted white, again I had the white enamel to hand so used what I had. Several coats were needed until I was happy with the finish. Parts of the structure were painted grey in accordance with the colour scheme and before I knew it I had an almost presentable tug. It's amazing what a difference a coat of paint makes. I thought I was nearly done. Final finishing was going to take longer than I could ever imagine.
Photos showing paint progress, final photo shows the wooden rubbing strake being fitted.
With the hull painted it was time to fit the drive train. I found the motor and my alignment jig but couldn't find the prop shaft with its fitted prop. I had been invaded by Borrowers, you know those little people who live under the floorboards "borrowing" things from us humans. I couldn't find the propshaft anywhere. Not on my desk, under the desk, not in my workshop (shed). Also missing was the nice slatted wooden cover over the rudder mechanism. I turned the house upside down but couldn't find them anywhere. Reluctantly I ordered a replacement 4mm shaft and a nice 3 bladed Raboesch brass propeller that I thought would look much nicer than the plastic one I had mislaid from the kit. While waiting for the post I added the timber diagonal rubbing strakes and the bulwarks stanchions & limber boards. The limber boards were lasercut ply and a lot lighter in colour than any of the photos with the kit, a wipe over with a little woodstain soon sorted that and with a little woodglue and some spots of cyanoacrylate they were fixed in place. They fitted just fine and only needed a little trimming at the stern. I also remade the slatted rudder cover, only just had enough wood strips in the kit.
The prop & shaft arrived and were promptly fitted together and with the motor aligned I glued the motor mount in place with epoxy, after all I have never had to replace a motor in any of my boats so wouldn't need to change this one would I (famous last words!). I slid the rudder in place and fitted the control arm then headed to the test tank (or bath as my wife prefers to call it). With a battery pack, ESC & motor temporarily connected I turned on the transmitter and flicked the switch. The motor ran and the boat moved and then stopped. It took me ages to notice that one of the bullet connectors to the motor had come disconnected. Reconnect the motor and all ran properly. A very successful test and no leaks anywhere!
Now just to add a few finishing details and off to the boating lake. The ships boats were my next problem. They are plank on frame with lasercut frames held in a ply jig while the planking is added. The planks made from 3 x 1mm strip wood. I looked in the kit, I had plenty of 5 x 2mm strips that the main hull was planked with, I reccon I could make another hull with it, but no 3 x 1mm. I probably should have complained to the manufacturer or supplier but a few strips of wood were not expensive so I ordered some. Planking up proved to be one of the most frustrating excercises I have undertaken. Extremely fiddly and annoying, after all the boat was nearly finished I just wanted to sail the thing. Well eventually the boats were finished and after a couple of coats of paint dont look to bad, They won't win any prizes for beauty but I think that sat up on their support frames they are passable.
Looking really good.
Wonderful looking model, how did you find the kit quality?
Overall the quality of the kit was very good, all the lasercut parts fitted together well with only minimal adjustments needed. A couple of the cast white metal parts needed a bit more fettling that I would have expected, the deck winch body for example needed quite a bit of work to enable it to sit square on the deck. I was disappointed to have a slightly bent prop shaft and missing planking for the ships boats but apart from that would be happy to recommend the kit to anyone. The tug was one of two that I liked the look of and have been very pleased with the end result.
Finishing touches. The bulk of the cast white metal fittings were fine with only minimal finishing required before painting and assembly. The four sets of twin bitts are attached to short lengths of dowel before being painted black and glued in place along the bulwarks at bow and stern. The large single bitt treated in a similar way and mounted on the small raised deck at the prow. The anchor winch however I was slightly disappointed with. The flat side that sat on the deck was distinctly angled and needed a lot of fettling before it would sit level on the deck. However once fettled and painted it looks ok.
There were a nice set of cast turnbuckles that I painted but only used four. I wasn't satisfied with any method I came up with to attach them to the brass eyes supplied with the kit. I tried opening up the eyes and succeded with a few but broke many as the brass was very brittle so decided to tie the rigging directly to brass eyes glued to the bulwarks and not use the turnbuckles. I'm happy with the result although it's not how the instructions indicated it should be. The portholes are white metal castings and needed short lengths of brass wire glued across them, thick cyanoacrylatedid the job and after painting they looked great. They all popped into their respective lasercut holes with no problem.
Next were the tyre fenders. These again cast white metal painted black but while looking ok were extremely heavy and I was beginning to fear for the weight topsides so looked for an alternative. On Ebay I found a british seller supplying a range of tyres for Dinky and Corgi cars. He had a set exactly the right size and thickness and for a little over £3.00 for a pack of 10 seemed great value. I ordered some. When they arrived they looked the part and were so light that once fitted would have little effect on the tug's stability.
With all fittings on board the battery pack sitting on a wooden tray fitted to the hull, the smoke unit restrained by a ply ring glued to the keel and all the electronics secured it was time to work out how much ballast it would need. So back upstairs to the test tank armed with a big bag of bolts that would allow me to distribute weight along the inside of the hull temporarily to see how it sits on the water. By carefully placing the bolts where I thought ballast would be needed I managed to get the boat sitting nicely on the waterline. Connected everything up for a quick try to see how it went with the extra weight on board. Turned everything on and it went backwards, no problem I just need to reverse the wiring to the motor. moved the throttle the other way and the motor sprang to life, slowed down and then stopped accompanied by a puff of magic smoke from the ESC. Turned it all off and plodded slowly back to the bench. Would I ever be able to get the thing finished?
So back to the workbench where I first directly connected the motor to the battery and it worked! Reconnected everything else and the rudder moved but the motor wouldn't so the BEC was ok but the ESC was definitely broken. I turned to Mayhem forum and took in the advice given, one comment was that the motor I had chosen may be a bit fierce and suggested I tried the MFA RES540/LN which would be more gentle. OK I had to get a new ESC so I ordered a new motor at the same time.
So whose daft idea was it to glue the motor mount in position? My rather rash decision had come back to bite me. There isn't a lot of room to get fingers inside the boat and I couldn't find my right angled screwdriver anywhere. However with a lot of fiddling I managed to get the two M3 cross head screws out and removed the motor. Putting the new one in however proved to be a bit of a trial. I just couldn't get the screws started, I didn't have enough hands and there wasn't enough room to get any more in even if I had any. I gave up, thought for a while and ordered a small batch of M3 alan headed machine screws. This turned out to be one of my better ideas, the screws stayed on the alan key and started in the threaded holes just fine and the motor went home with no problems. Something to remember for future builds.
Time to sort out the ballast. Taking the temporary ballast (bolts) out from each part of the hull seperately, weighing them then replacing the bolts with lead shot bought from an outfit that provides lead shot for scuba divers for weighted belts. The shot is weighed out and placed in a strong plastic bag, I started using small ziploc bags but ran out so ended up using bank moneybags. The bags of lead then fit snugly into the bottom of the hull with a bit of manipulation and won't move readily, no glue necessary.
The new ESC arrived and was duely connected up. With a heavy heart I turned on the transmitter, flicked the switch and everything worked ok, Phew!
The final finishing touch, a front fender. I talked it through with my wife who said that she could probably crochet something. I had a reel of cotton thread that came with the kit that turned out to be just enough. So now the tug is complete, I think. Just the debate about wherther or not to add crew. I am undecided, will give it some thought and see whats available at the correct scale 1:30.
Just need to try it on the lake........... What? not allowed to go out!!! The Coronavirus pandemic has decided that Ulyses will be a static model for the forseeable future. I will get out with the boat at some point but quite when I have no idea. When I do I will take some photos and post here.
So my impressions of the kit.
I thoroughly enjoyed putting it together, apart from planking the small boats. The tug was one of two that I liked the look of and have been very pleased with the end result and cannot wait to get out on the boating lake with it.
Would I have done anything differently? I think I would have spent a little more time profiling the ribs at the bow before planking to give a slightly sharper look to the front end. I definitely would screw the motor mount in rather than glue as that would have saved hours of frustration and saved myself all the coins that went into the swear box. I need to live with my fixed switching for the lights to see how I get on, it's quite possible that at some point in the future I will change to a RC switch of some kind to allow remote switching which would raise the spectre of wire connections between the hull and the superstructure, but thats all for another day. Would I buy another Occre kit? Well based on this one probably yes if they had something else that I fancied.
And finally we have made it to the lake. Maiden voyage at Kearsney Abbey accompanied by my good wife and the grandchildren. Lovely afternoon with perfect water conditions. Apart from a slight list to port which I will solve later by shifting some ballast she sailed extremely well. The motor was nice and responsive and she has a pleasing turning circle. I was very impressed with my homemade cold steam generator which photographed surprisingly well.
The tug looked an absolute picture on the water in the sunlight and didn't look bad when it went in. Really looking forward to taking it out again, without the grandkids so I can enjoy the boat with a little more peace and quiet. Thoroughy recommend this kit!
Wow, what a beautiful vessel you've built. Look very nice on the water, congratulations.
