The Shipyard ( Dry Dock ): Builds & Questions => Steam => Topic started by: Martin (Admin) on August 22, 2021, 12:11:06 am
Title: Silver Soldering A Model Boiler : Failure!
Post by: Martin (Admin) on August 22, 2021, 12:11:06 am
YouTube: Silver Soldering A Model Boiler : Failure!
Title: Re: Silver Soldering A Model Boiler : Failure!
Post by: Baldrick on August 22, 2021, 09:30:26 am
If you don't know the right (suitable) flame to use :-X
Post by: Jerry C on August 22, 2021, 10:10:36 am
I think she over thought it. I used a similar method with solder rings. Mounted it vertically in a home made kiln and used big burner on propane. Kept as much heat in as possible and aimed the torch at the top inside the tube. 12 minutes, top done. Flipped it and another 12 minutes did the other end. Finally did each bush separately. See my YouTube channel captainpaxo1. Hydraulic test, no leaks. She never mentioned pressure testing in small increments to avoid bulging. It appears she took it up to final pressure in one go, hence the cracks?
Jerry C.
Post by: Martin (Admin) on August 22, 2021, 10:51:09 am
YouTube: https://youtu.be/xYxXb7u45Fg
Post by: rhavrane on August 22, 2021, 11:21:53 am
Bonjour, One of my boiler, yet tested at 145 PSI, has had a minuscule leak at about 45 PSI and the result was quite impressive : https://www.youtube.com/watch?v=h3CSpw-AiRo Hopefully, it has been it has been repaured since this episode.
Post by: Jerry C on August 22, 2021, 11:29:50 am
Thanks Martin. A 5” return flow scotch boiler. This is how it looked after cleaning. Undergoing hydraulic testing.
