Technical, Techniques, Hints, and Tips => The "Black Arts!" ( Electrics & Electronics ) => Topic started by: botchit on November 18, 2007, 09:00:14 am
:( could anyone tell me the purpose for the solder tags from both the battery cables to ground? and what is the best size wire to use for them.
I think we need a bit more information Botchit :)
Quote ............
Both battery cables to ground ?????????????
Your going to need 50 amps here as it sounds like a DEAD short across the battery.
Hope I'm wrong ;D
Cheers...Ken
Hi Guys.
took closer look at drawing, it appears that one wire from batt cables splits into two and fastens to servo plate via two nuts and bolts.
Misunderstood instructions somehow sorry.On this point instructions for speed controller don't show this wire on batt connections :embarrassed: :embarrassed:,is it an earth of sorts ? do i need it?should i use the same wire as for light system. It's my first attempt .( will probably name it mv plastic padding )
botchit
Could you take a step backwards, what is it you are trying to connect.
Which thread is the diagram in? Knowing which diagram would make providing an answer much easier.
