Technical, Techniques, Hints, and Tips => The "Black Arts!" ( Electrics & Electronics ) => Topic started by: Guy on February 07, 2008, 07:07:45 pm
I have a small trent class life boat from model slipway, it is 500mm long and 180 wide. I have installed 2x M2 prop shafts with 30mm 3blade plastic props. They are run by 2 MFA torpedo 400 motors via an mtroniks viper 15 ESP and a 6 cell 2000mAh battery pack.
My problem is that the plastic props have broken, got damaged in the car and lost a blade or two on the water. Also she is slightly slower then I had hoped.
Can anyone point me in the direction of a supplier of brass props for M2 shafts?
Also i have now wired one motor the opposite way around so would therefore need one RH and one LH prop, is this correct for a twin screw boat?
Is there any way i can get more power out of this set up? The battery lasts a long time so more jucy motors could be an option but would i gain anything with out changing the battery?
Thanks for any advice, Guy
I had a 3 bladed brass prop made to fit an unusual size shaft a few years back. This was done for me by a company called SHG.
Hope this helps
Alan
PropShop could supply off the shelf.
But dont know the situation since the takeover.
Try red bank models Wingertaz on the forum pm him
Hi Guy, my 400 motors run on 7.2v
I am also making the George Turner MTB which he reckons will run well on the Graupner speed 400 motor with a 7.2v 2000mAh battery and a 2 blade 25mm prop.
The MTB is more or less the same size as your lifeboat.,
Dont know if this helps. :-\
Try Gsitek props, they are good and give excellent service.
http://www.gsitek-props.co.uk/
Ian
Thanks for all your help, I wish I had asked yonks ago!!
Its reassuring to hear other peoples tales ad tips.
Guy
How else do you think the rest of us got to be such smart asses?
Welcome aboard, amigo.
PMK never a truer word spoken in jest O0
