Technical, Techniques, Hints, and Tips => The "Black Arts!" ( Electrics & Electronics ) => Topic started by: sunnybob on February 18, 2008, 08:21:59 pm
I have finally started to put together the electronics on my cruiser, and my single sheet of instructions just dont cut the mustard (nothing unusual there >>:-()
I have 2 x electronize 545/12 motors, controlled by a single elctronize FR30HX esc.The diagram shows a fuse between the battery and motor, but nothing as useful as a value by the side of it ::) ::)
Suggestions please?? :) :)
Also, while youre here, I have 2 x JP energ 6.0volt motor batteries. Can I rig them up in parallel to give me more run time? or will that overload the system with too many amps?
All help gratefully received :D :D
The fuse size to fit should be no greater than the max continuous current rating of the esc - if you have any doubt about what that is or should be, contact electronize, they will tell you.
As for the batteries, assuming they are gel cells, yes you can rig in parallel without risk, that will give double the run time of a single battery.
The amps pulled in the system is dependant on the type of motor and size of prop, so parallel connection of batteries has no influence on this.
I recommend connect up one motor/prop to the battery - exclude the esc at this time, and measure the amps drawn by connecting an ammeter between the motor and battery. Do this with both motor/prop drive lines. This will give you the total max running current of the set up.
As an aside, I have fitted fuses between the motor and esc on a twin motor setup - ie. 20amp esc feeding 2 motors, each motor has a 10a fuse between it and the esc. This means the esc cannot be overloaded and, if one prop gets fouled up and stalls a motor thus blowing the fuse, there is a good chance the other motor will get the boat back to shore.
Hope this helps
Ian
Ian, your post has answered some, but raised other questions.
My digram from electronize, shows the (single) fuse between the battery and the esc.
But i like your idea better, as hopefully one of the motors will still run if a fuse blows.
But whats the likelihood of a short between battery and esc.
I know that each fuse adds load to the circuit, would it be "overkill" to have a bigger fuse between battery and esc as well as the 2 smaller ones?
The esc handles 30 amps, so logically, I should have a 30 amp before the esc, and a 15 amp on each motor?
The motor batteries do not have any amperage on them, but they are NiMH, is that the same as "gel"?
The actual label reads 6.0volt SC-3300H FLAT. Any idea what that translates as?
The electronics wiring isnt finsished yet, so at the moment I cant try a motor. But I do have the meter and ability to find out the current draw.
Thnaks
Fuses don't load the circuit, they are just a thin bit of wire that will "blow" if the current exceeds a certain level.
NiMH batteries are Nickel Metal Hydride. "Gel" cells are lead acid and not the same at all. The main difference is that the charging regimes are different. Plenty of info available if you just Google!
NiMH batteries should normally state their amp hour capacity Not sure exactly what your label means but it suggests that the capacity is 3.3 amp hours (3300 milli amp hours). The quoted voltage of 6v suggestes that there are 5 cells as each NiMH cell has a nominal voltage of 1.2v.
Using my suggestion of fuse after esc, the battery connects straight to the esc, so there is no way a 'short' can take place, unless of course the positive and negative leads come into contact - and we all know not to allow that.
You really only need to fuse one side of the esc - either twix battery and esc, or esc to motor. There is nothing to gain by fusing both sides as the 15a fuse between esc and motor will always pop before the larger between battery and esc.
As for the Nimh batteries - I stand to be corrected here, but it is my understanding that you have to be very careful connecting these in parallel, because if they are not balanced electrically, there is potential for one battery to feed another with potential overheating and exploding issues!
Incidentally, I blew up a Nimh pack accidentally by overcharing, it was a AAA PACK.Two of the cells disintegrated completely and there was powder everywhere!
So, the moral is - be careful, there is a lot of energy in those little batteries.
Ian
colin, absolutely right, there are 5 cells in each battery.
So does my original plan of 2 of them in parallel cause any problems?
If they are only 3.3 amp each, then the 30 amp controller wont be bothered.
Now I'm wondering if I should get more batteries? I have no idea how long the motors will work on those sizes. I can see me having a bordom threshold of around a hlaf hour. will the boat last that long?
O0 O0 O0
Ian, how do I balance these batteries? can I charge them in parallel? Or do I need a diode in each line to stop back emf?
Once again, the deep end is where I appear to have settled into, without bothering about the shallows ??? ???
OK, youve saved me one fuse O0 the search for the pefect system continues ;D
Bob,
The rating of the batteries at 3.3a indicates that they will supply 3.3a continuously for 60 mins, or for example, 33a for 6 mins!!!! or 66a for 3 mins!
So, you need to think in terms of amp/hours, hence when a battery is specified as, say, 3.3ah. or 3300mah (these are both the same rating).
So, as you can see, the esc can be overlaoded by these batteries, but, as I said before, the load depends on how much work the motor has to do to turn the prop and drive the boat.
Ian
Again, I stand to be corrected, but I understand that for these batteries, you need to match the individual cells inside the battery at the time of making up the pack.
For your application, I suggest you think about using one battery at a time, bring the boat in as it runs down and change the pack - or fit wiring and a changeover switch so you can swap batteries by flipping a switch over.
You should be aware that these batteries give full performance almost until flat, then drop off very quickly, not leaving you much to get back with if you are a long way out. You should experiment and get an idea of duration on the water.
Depending on the type of boat you are putting them in, it may be worth thinking of a gell cell (sealed lead/acid).
Ian
"xxxxx"! now I'm worried.
This old boat has bronze rods inside close fitting brass tubes for the props. There are no bearings, and there is a fair amount of resistance, even turning the props by hand.
I can see them causing a huge amperage to turn them properly.
I need to make a jury rig and see what these props pull from the battery before i commit any other resources.
Thanks Ian, even though youve given me more work, rather that than watching the boat catch fire on its maiden voyage.
bob
Good luck and keep us posted.
Ian
Sunnybob if I was you I would take the shaft out and clean them up with 1000wet dry in case there is rust on then reassemble packing the shafts with grease spin then up just with the batt no esc and feel the shaft tubes to see if they are getting hot.If they are well as NASA would say HUSTON WE HAVE A PROBLEM but thats another story.
Very little likelihood of that, but a possibility of a problem inside the ESC. The fuse between the battery and the ESC protects the rest of the boat from the possibility of an electrical fire. As a previous poster has said, there is a lot of energy in those batteries, and you don't want it all let loose inside the ESC in a few destructive seconds.
Stavros, no rust on these babies, 50 year old bronze shafts. Must be worth more than the boat!!! But yes, I think houston should be put on defcon 3 {-) {-) {-)
mmmm. looks like I might as well use 3 fuses instead of two that was originally one. ::) ::)
Posh shafts then but one question have you had them out and regreased them???????????????????????????????
sunnybob
I saw a post of your on another site I think , and you only have about i/2 a mill clearance iner to outer shaft so dont put grease in,
fredy
This might help you:
http://www.modelboatmayhem.co.uk/forum/index.php?topic=8674.msg84258#msg84258
PM me for any further info - I've got loads of it.
FLJ
As previously stated, there is a risk of a short in an esc, there is also a risk of an internal short developing in batteries. You cant get protect from internal battery shorts with a fuse.
The bottom line, I think, is that you have to determine what is an acceptable and reasonable risk compared with the cost required to minimise that risk.
I have never had an electronic failure or a disastrous short in over 10 years, but there is always the risk!
Ian
Just a reminder of what can happen with an internal short in the ESC.
I recommend fuse between battery and ESC.
Very graphic, Bob.
Its got me thinking again, for the price of a fuse and holder............. :o
wow, so many replies,
so here are the answers to each of you.....
Stavros, yes i have greased them, thats the problem. This boat was built 50 years ago when R/C models needed a suitcase to carry the transmitter. Its all hand built, but is now not compatible with modern stuff. Those shafts were made for something like a half horsepower motor to work both through a hand built double splitter crown wheel gearbox. Theres no room for bearings, no room for seals, just no bloody room for anything :'( :'( and these poofy little new motors are going to have earn their keep.
Proteus, yes, thats me, struggling to get this boat in the water without mortgaging my inheritance (hey, this boat IS my inheritance).
FLJ, they look terrific (shows what a sad person I am when I can get excited over a FUSE!!! {-)) but as already posted, total cost is number one issue with getting this boat going.
Boatmadman and shipmate 60, I'm convinced, If this boat were to catch fire for the sake of a fuse, my brother and sisters would hunt me down and drown me in a sack. :o :o
To all.... I've now tested the prop shafts, one is good, one makes a lot of bad noises. Obviously one of the shafts is bent and rubbing. It looks like I am going to have to find a way of fitting two new shafts through the hull . C.R.A.P.
Bob,
What is the inner diameter of the tubes, and the diameter of the shafts? Could you bush the tubes and run a smaller diameter shaft?
4mm diameter shafts are plenty strong enough for most applications.
Ian
No, the problem is in the tubes. because of the age of this stuff, its all home made. the tubes are just rolled brass, 1/4" outside diamter, and the shafts are a sliding fit inside them. I did grease the shafts, and the turning resistance was huge.
Theres not enough free tube at either end to start cutting or altering them. Theyre 14" long.
I think I'm going to have to buy new shafts, as I saw some at a model shop recently, and they had bearings and all manner of new fangled bells and whistles. Luckily, they are thicker rather than thinner, so I will just have to enlarge the holes through the hull, But then I will have to work on brackets to hold them. SIGH.
I think I should have found this place and asked these questions BEFORE i talked my brother into parting with it. :'( :'(
If the tubes are a long way to being doomed, why not un-lube them, then "lube" with Brasso, and run them for a few minutes slowly. They should show signs of freeing up, then when they sound a bit better, clean off the dead brasso, lube with oil, and try again.
Measuring the tube on my Graupner Lotse, the OD is 6mm, a bit smaller than most, and about the same as yours, but still with a 4mm shaft and bearing bushes. A pair of Graupner shafts might do the job failing all else.
If they are that large a diameter cant you fit a "modern" complete shaft inside the original tube.
Having spent some time now on examining the shafts and tubes, I think they are for the scrapper.
One of the shafts is no longer true, and I dont have the machinery to re-true a 14" x 5mm shaft.
Also one of the rolled brass tubes is coming apart at the seam at one end.
Its sad, because these were the only parts of the 50 year old running gear that I have left, but they are just not vible to repair, considering they can be replaced for around £25.
So now I am in the market for a pair of 14 or 15" tubes and shafts, anyone have any suggestions? I've tried redbank and they are out of stock.
http://www.westbourne-models.com/erol.html#5605X0
should be westbournes shafts and props page. The shafts are shorter than you want, but might be long enough to do the job. Being the same-ish OD as the existing ones should make the replacement easier. Relatively speaking.
http://www.angliamc.fsnet.co.uk/
Anglian Model Centre do shafts from 5" to 20" M4 and M5.
I swear this boat is going to make me lose whats left of my hair >>:-( >>:-(
I have spent even more time on these props, and I think I can make them work at least for the time being.
I've filled the tubes with a cleaning paste, and spun the shafts with the motors, so they have honed themselves. the slight seam split I can solder shut.
Not perfect, but this isnt a competitive racing boat I'm dealing with.
I just cant believe the mares nest of all the wiring plugs in this hobby. And each time I ask for one type, i get told that "theyre a fire risk" or "phew, wouldnt trust them to stay connected" time you lot got together and picketed the manufacturers at some trade shows. :o :o
On a positive note (cor, there's a first), having given up trying to find my Bronze paint in useable sizes, I walked into a toy shop today to look for a couple of 6" human toys to put in the boat for a scale comparison, I turned a corner and quite literally, there were 50ml tins of bronze at face height O0 O0 O0 O0
Made by Humbrol, who dont even list these on their web site. i expect theyre as old as my boat is, so that will be nice to paint {-) {-) {-)
Bob, half way down a very very long road. ;) ;)
When hunting down connectors I think many of us head for our nearest auto accessory shop. The "proper" model stuff has been developed for the ready made market, and in that context is fairly foolproof - it is difficult to connect incorrectly. If you are making your own up, auto connectors are much less fiddly and more reliable. The alleged fire "risk" comes from trying to use economy parts in high performance situations - e.g. you wouldn't put old remoulds on a Sierra Cosworth and expect to live long - using components rated for relatively low current is not good in a racer, but gold plated contacts are a waste of money if they are only going to carry a fraction of their rating.
Malcolm, youre absolutely right. I now have more gold on my connectors than I have ever owned before in my life. :(
My problem has been that I quite literally "catapulted" into this hobby from a standing start, with absoluutley NO experience of anything useful in completing my boat, and am still sorting the wheat from the chaff regards people I can and cant trust for info.
This forum has been a godsend for me, I have learnt more here than the two nearest "specialist hobby shops" have told me, and I now know to discount entirely one of those. >:(
I AM making progress, its slow, but with the help of you lot, its definitely progress. O0 O0 O0
It aint rocket science Bob, though there are people on here who treat it like it was ie gold connectors when your cruiser or whatever will run just as well using the old fashion block connectors. They try to set up their R/C so it will achieve 1/4 mile range when you cant see the damn thing after the first 150 yards.
They set up motors, batteries, speed controllers and props so that the model will run allday on one charge, who sails continuously all day ? The idea Bob is to get your model set up to suit you not anyone else. Accept advise but dont take it as gospel. You wont be long on here before you figure out that there are several people on here who give the sensible straight forward advise that you can understand and there are some that waffle on for ages quoting this that and the other in all their wonderful technical terms, at the end of which you wont have understood a word. All trying to be helpful in their own way.
Waffle over, enjoy the hobby. ;)
Bob,
Is there any way you can post pics of her on here?
Well said Richard. Regarding connectors, I have standardised on the Deans variety as, provided they are all wired with the same polarity, it is impossible to connect them incorrectly. They are also extremely corrosion resistant, important to me as we sail in salt water. Using this method, I am able, if neccessary, to interchange batteries, motors and speed controllers easily and quickly. I started off using the Tamiya type, but had some problems with these, and after trying another kind, settled on the Deans. However, this is just my personal preference, and newcomers to the hobby would do well to heed people such as yourself.
Peter.
Bob,
I havent been able to find any gallery on this site. I have just a couple of the boat on my brothers website.
www.pbase.com/john_cooper/boat_rebuild_project
Not much yet, but more are due as and when I manage to get the electronics under way.
She looks an attractive model, and the shafts looked good too.
I can see why you wanted to keep them.
Nice looking boat, and yes, the hardware looks good.
Ian
I can see why you wanted to keep the original hardware. Someone put a lot of work into it.
That was my Dad. He was a first class metal worker and engineer. He did all this when I was still at primary school (45 years ago now), thats why I'm trying so hard to keep it all together.
Commercial value? fourpence three farthings.
Sentimental value? priceless.
Your photos as requested Bob O0
Bob,
One company (and I cant remember which one but someone on here will know) produce shafts ends that are nylon.
Might it be worth considering fitting these to your shafts, you can get the inner shafts in 4 or 5 mm.
Thanks, but I'm OK for now with the shafts. they aint pefect, but theyll do.
This whole rpoject is just to get the damn boat going, after 40 years of sitting on a shelf. I'm desperately trying to keep costs to a minimum.
If the boat actually works, and I find I like the hobby, I might upgrade in the future. But for now, I just want it in the water and running ::) ::) ::)
bob
