Author Topic: Servo Wire Colours  (Read 4807 times)
BreezyB
Servo Wire Colours
« on: April 16, 2008, 03:21:58 pm »
Can you help please.
My Futaba S3003 Servo leads are made up of a Red, Black and White wire. Could someone please confirm the identify of each wire i.e Positive , Negative and Signal.  It's tempting to assume the obvious but I need to make sure.  :-\
Many thanks
Barrie.
alan colson
  • I Just Dabble In Model Boats
Re: Servo Wire Colours
« Reply #1 on: April 16, 2008, 03:33:56 pm »
According to the instructions with an M.sonik-4 Marine 15
position 1 signal white
position 2 +5v red
position 3 ov, common black
hope this helps
Alan
BreezyB
« Reply #2 on: April 16, 2008, 09:10:21 pm »
Thanks Alan. Indeed it does help  O0
Barrie.
maninthestreet
« Reply #3 on: April 16, 2008, 11:22:40 pm »
A picture is worth a thousand words:
http://www.fatlion.com/sailplanes/servos.html
andrewh
« Reply #4 on: April 17, 2008, 08:21:47 am »
For what its worth the palest lead colour is always the signal, and on all receivers I have met the signal wire is always closest to the electronics.
Darkest wire is negative and the other is positive.  Negative is usually (but not universally) the furthest from the electronics of the receiver, with pos in the middle.  They are arranged, I think in this way so that there is no smoke emitted if they are put in the receiver the wrong way round - but there is no servoing either!
I have one ancient sanwa servo where all three wires are black, and I had to take a guess at what they were, and got it right.
andrew
alan colson
« Reply #5 on: April 17, 2008, 04:06:01 pm »
If using Airtronics receivers the red and black wires are the wrong way round according to M-Sonik-4 Instruction Sheets, so check this out carefully. This seems to be the only exception to the rule.
Alan
BreezyB
« Reply #6 on: April 17, 2008, 05:24:03 pm »
Ta very much for your contribution Chaps (fatlion.com link very useful) . The  I think I can safely connect it all up now, if you don't see a mushroom cloud over Hertford this weekend, it has all gone OK.
Thanks again to all,
Barrie.
Page created in 0.012 seconds with 20 queries.
