Bluebird first....
only one t/x. only one r/x. crystals not swapped. T/x battery fully charged, and rechearged just to make sure.
I've tried an independant 6 volt supply direct into the r/x, and still no change.
I agree, the relay and servo appear to have no signal, BUT, the motors and servo dont hunt when the T/x is turned on, but do when its turned off. To me that indicates that the esc IS getting at least part of a signal?
FLJ.... I saw you at shepton on Sunday, loitered around a couple of times to speak to you, but you were too busy selling for me to interupt :) :)
I dont know what a bec is. My system is this... battery direct to your board (inline switch on live). r/x connected direct to your board. esc power from your board, esc control wire and servo direct to r/x.
the esc is a non-bec type (it says on the instructions). regarding the plugs to the servo, i mean just turning them round, not moving wires inside the plug.
Like I say above, I have stripped the entire system to a battery pack, r/x, and servo. STILL, the servo will hunt if the T/X is off, but be absolutely motionless if the T/X is on. Even moving the servo plug to each of the 7 sockets on the r/x makes no difference.
Bob, (searching for a bottle opener) :(
