Nearly at the end now ,well probably not we never finish them ,allways find something else to do.
As it was getting dark i thought the lights would need testing to see how they looked.
And then it was down to the water for a pond test.
The result looks great in the water ,a little under powered but i was told that it would with the motors i had fitted ,as i did not intend to use her for heavy towing it wont matter ,but i may replace them in the future .
The other thing i found is the bearing seal on the bow thruster motor is leaking and as a result water is getting into the boat through the motor casing ,it is not a lot and after 2 hours of running there was only a little bit in the hull ,if it gets too bad then i will fill the can up with resin as the motor cannot be removed easily.
My thoughts on the kit ,excellent and thanks to Lawrie and Jackie for producing it, there are others who may build it their way and thats ok as we have the choice and our own preferences .
daz
