Author Topic: Tug Motors: What Tug do you have and what motor setup?  (Read 29020 times)
DaveB
Re: Tug Motors: What Tug do you have and what motor setup?
« Reply #25 on: October 18, 2008, 07:10:44 pm »
Tyne Tugs
Flying Phantom
Bosch Car blower motor
Futaba Skysport 4 Electronize 15amp esc 40 working lights 2 windscreen washer pumps for the monitors powered by 2 12v 7 amp gel cells
nhp651
« Reply #26 on: October 18, 2008, 07:31:46 pm »
Caldercraft Imara with Cheddar steam boiler and two twin cylinder "Puffin" steam engines..but gotta confess.......I'm a chicken and haven't steamed em up yet.. :'( :'( <:(
ronkh
« Reply #27 on: October 18, 2008, 08:08:02 pm »
Shame on you.
Fire them up and post some photos. O0 <*<
nhp651
« Reply #28 on: October 18, 2008, 09:02:06 pm »
berrr cluck cluck cluck..............might leave it till next summer time.........might be waiting a long b****y time then, if this years effort was anything to go by. {-) %% {-)
ministeve
  • washing the decks!!!
« Reply #29 on: October 20, 2008, 08:23:46 pm »
this is what i use in an afon hull running 70mm thruster props
6705russell
« Reply #30 on: October 25, 2008, 10:30:27 pm »
Not far from finished is my Pusher Tug, this is powered by a Triumph Stags blower motor!  :-))
Russ
barryfoote
« Reply #31 on: October 26, 2008, 07:51:45 am »
Russ,
I like your springer, complete with an MMM safety coupling by the looks of her...
6705russell
« Reply #32 on: October 27, 2008, 10:38:11 am »
Footski,
Yes i have started to use these on most of my builds now, simple and straightforward, coupled with this motor it should pull most things.
Russ
More Coffee
« Reply #33 on: April 26, 2009, 12:56:58 am »
Billings Banckert (Re-Christened  "BENDER") freelance
(?) 500 series can motor, 6 pole internal fan, direct drive ..on a 45mm Rivabo 4 blade prop.
Hitec Ranger III.. Channel 1 steering , Channel 3 throttle
ggeorge
« Reply #34 on: April 26, 2009, 03:57:46 am »
  I have used a variety of motors in a variety of builds. But for larger tugs I will used a power seat motor. They are a low rpm and have lots of torque and can be used as a direct drive. On TID tug I am building this motor will be turning a 4in prop. I will give you an update after the water test.
  G. George
oldiron
« Reply #35 on: April 26, 2009, 09:53:24 am »
SS Master, based on a Dumas Brooklyn hull
power seat motor driving 3 3/4" prop. It can pull a large person in a row boat.
Airtronics FM 4 channel, two channels used at the moment.
12 volt 7ah sealed gel cell battery
bulerthebishop
« Reply #36 on: May 26, 2009, 01:23:18 pm »
Mobile Marine  Ayton Cross
                     2X Torpedo 800 (Direct Drive)
                     Spektrum 2.4
                      12v
andywright
« Reply #37 on: February 26, 2010, 11:54:55 pm »
Mobile Marine Models Nangee,
Bosch blower motor driving single Prop Shop 68mm prop in MMM70mm Steerable Kort. Electronise speed controller. 12volt.
Loads of power and torque :-))
Navigational Aids vessel Master. Old Conway 70-72
timsenecal
« Reply #38 on: February 27, 2010, 03:52:00 am »
#1
Dumas Mr. Darby
2x cyclon 600kv brushless outrunner/3:1 belt drive reduction/Castle Creations Mamba Micro Pro ESC/2x 6 volt 36 amp SLA
6 channel Assan 2.4ghz module/receiver in a Futaba 9c
#2
Dumas Lil' Shelley Foss (24" model)
2x E-flite 400 740kv brushless outrunner/2:1 graupner gear drive/Castle Creations Mamba Micro ESC/2x 6 volt 5 amp SLA
seahawk 1
« Reply #39 on: February 27, 2010, 03:53:37 am »
Model Slipways Dutch Courage-built as tug Mustang
Astroflight 40 marine motors w/3.3:1 gearboxes
50mm kort 4 blade rabeosch brass props
Vantec RET512 speed controls
Rabeosch 30mm bowthruster w/Vantec RET411 speed control
2 x 12v 7.5 ah SLA batteries Harbor Models power distribution unit.
Harbor Models Pacific Escort-being built as a freelance Rotortug
3-Graupner 1761 schottel drives
3-Graupner 2.33:1 gearboxes w/speed 400 motors
12v 5ah SLA
3-Vantec RET411 speed controls
MilanS
« Reply #40 on: November 03, 2010, 10:51:37 am »
Damen ASD 3111 - Pawlina http://www.mo-na-ko.net/php/portal/view.php?cisloclanku=2009020005
Motors 2 x Graupner 900BB Torque, 2 x own shottels http://www.mo-na-ko.net/php/portal/view.php?cisloclanku=2008080006
2,4 GHz JETTI Duplex - 8 channel
Damen Stan Tug - Jenis http://www.rcfogli.cz/modules.php?name=coppermine&file=thumbnails&album=229
Motors 2 x ROBBE 755/40, own bow thruster http://www.rcfogli.cz/modules.php?name=News&file=article&sid=102
2,4 GHz JETTI Duplex - 6 channel
Kotug (rotortug) - RT Antonie (under construct) http://www.rcfogli.cz/modules.php?name=coppermine&file=thumbnails&album=278
Motors 3 x ROBBE 755/40, 3 x new schottels http://www.rcfogli.cz/modules.php?name=News&file=article&sid=114
2,4 Ghz JETTI Duplex - 8 - channel
tubby tomo
« Reply #41 on: December 10, 2010, 03:18:58 pm »
hi 2 75m props in fixed korts 2 24v motors 6 rudders 5ft long its a bit on the Waite side 80lb
tugmad
« Reply #42 on: December 10, 2010, 07:33:46 pm »
Scratch built 1/24th scale Contest and Ocean cock  both fitted with Astra 1.6 cooling fan motors  and M tronics 20amp speed controllers swinging 110mm props.
and Planet 5 radio gear.
tugnut
« Reply #43 on: December 10, 2010, 09:28:05 pm »
Hi all this is my damen 1906 stantug Fitted with two MFA 500 PLUS action 94 controller.
regards John
tugnut
« Reply #44 on: December 10, 2010, 09:32:30 pm »
This is my Hollygarth fitted a 12V fan motor plus electronize conroller.
regards John
brianB6
« Reply #45 on: December 10, 2010, 11:33:12 pm »
All these big motors and props would seem to make my 1:48, 28" Cervia, under powered.
A 40 year old, 500 size motor and a Graupner 50 mm. 3 blade plastic prop but she almost planes and the bow wave can be as high as the rail!
Page created in 0.037 seconds with 22 queries.
