Author Topic: Transmitters  (Read 3753 times)
Garabaldy
Transmitters
« on: May 02, 2008, 09:59:08 am »
Been looking around for a 6channel transmitter but im having trouble...  Ive been looking at futaba ones but they mostly say they are for air craft?  Is it still possible to use these for boats?  Or alternativly can any one recommend a good cheap 6 channel transmitter?
Gary
FullLeatherJacket
Re: Transmitters
« Reply #1 on: May 02, 2008, 10:16:23 am »
Gary
To my knowledge the only dedicated R/C set for model boats is the Robbe Futaba Navy F14/16/18 range. It is very flexible with its add-on modules, encoders and decoders, but it can get very expensive if you fit them all! Check out Westbourne Models' website for details of this set.
Most modellers use a standard 6 channel aircraft Tx* for their boats, perhaps putting a self-centering spring on the throttle stick instead of a ratchet. The fifth and sixth channels can be used to operate on-board switches for other functions like lights, fire-pumps, bells and whistles, but be aware that those Tx channels which are controlled by simple ON/OFF switches are very limiting (e.g. as fitted to the otherwise very good Futaba 2.4GHz set). Better get a Tx with at least one of the additional functions controlled by a lever, 3-position switch or rotary knob. If you're just starting out then a popular set is the Futaba 6EXA 40 MHz FM. The Hitech Laser 6 40 MHz is also a good buy. Avoid any Tx which has been designed expressly for model helicopter use, however; as a beginner you want the least amount of hassle you can get!
*Whatever you choose be aware that 35 MHz model aircraft sets are NOT legal for use in model boats in the UK; you need either 40 MHz or 2.4GHz. 27 MHz is still legal but I haven't seen a new 4 or 6 channel set on this frequency advertised for donkey's years.
FLJ
Re: Transmitters
« Reply #2 on: May 02, 2008, 10:20:54 am »
From previous posts on the subject, whatever set you do settle on, you will almost certainly find that the instructions are totally flight-oriented, this being the majority market.
Garabaldy
Re: Transmitters
« Reply #3 on: May 02, 2008, 10:56:23 am »
Cheers guys.  The Futaba 6EXA 40 MHz FM, does it come with any additional radio gear like reciever and servos or is it just the transmitter?  i cant see any mention of additional radio gear on the westbourne site
wombat
Re: Transmitters
« Reply #4 on: May 02, 2008, 02:06:19 pm »
If it is the kit retailing about £135 then it is a full set-up: Transmitter, Reciever, Servos (4 off), Rechargable batteries for the transmitter & reciever, charger & additional bits. Also comes with a pair of crystals......
However, you probably want to invest in at least one additional set of crystals - the normal ones that seem to come with the unit are 40.665 or 40.685 so everyone and their grandmother will have them. Also either spring return or ratchet upgrade for one of the sticks depending on whether you want ratchet or spring on the vertical sticks. Mine are currently ratchet but I am looking to upgrade to spring return.
Wom
Garabaldy
Re: Transmitters
« Reply #5 on: May 02, 2008, 03:14:00 pm »
perfect!
nightowl2912
Re: Transmitters
« Reply #6 on: May 02, 2008, 03:50:02 pm »
Hi Gary, have a look at the Futaba 6 ex 2.4 ghz, no need for crystals
about £150
catengineman
Re: Transmitters
« Reply #7 on: May 02, 2008, 04:57:49 pm »
On the subject of transmiters I was (am) thinking on giong down the 2.4ghz direction.
I know nothing about the magic contained within so I will and have to ask
 my FX 18 is expandable,  will a 2.4 ghz system be likewise (i need 11 ch at the moment) and I want yet more stuff to be controlled by me from the handset.
Or is it a case of stay with what I have and (the little glitches)
R,
a3nige
Re: Transmitters
« Reply #8 on: May 02, 2008, 05:41:52 pm »
Wombat,
This thread may help you with your spring return.
Nige
http://www.modelboatmayhem.co.uk/forum/index.php?topic=4629.0
"You're a hard person to ignore, but well worth the effort !"
barriew
Re: Transmitters
« Reply #9 on: May 02, 2008, 05:54:52 pm »
R,
As far as I am aware there is no 2.4Ghz equivalent of the F18. 6 channels is the maximum I have seen on 2.4Ghz. Do a search on 2.4Ghz on this forum for many discussions on 2.4G
Barrie
Garabaldy
Re: Transmitters
« Reply #10 on: May 02, 2008, 06:44:10 pm »
I will be spending the extra £15 and getting a 2.4 set.
