Author Topic: Wiring  (Read 4309 times)
Garabaldy
Wiring
« on: May 02, 2008, 01:14:18 pm »
This is embarassing but im going to ask anyway.  Where is a good place to get your cables from for wiring up batteries to motors speed controlers etc...  :embarrassed:
OMK
Re: wireing
« Reply #1 on: May 02, 2008, 01:21:38 pm »
Have you got a scrapyard round your way? Wiring looms robbed from autos are good for heavy-duty loads, such as motors, ESCs, etc.
And some bozo on this forum going by the moniker of PMK could help you out with smaller gauge wire for on-board lights, etc.
Name your colour.
Re: wireing
« Reply #2 on: May 02, 2008, 01:30:24 pm »
I tend to use "mains leads" for heavy cabling ( batteries, motors, speed controlls.
If I want colour coded wiring, I buy it at the shows or Maplins, or the local DIY shop.
wombat
Re: wireing
« Reply #3 on: May 02, 2008, 02:12:13 pm »
If you are buying small quantities then probably Maplin or you local electronics shop is the place to look.
I tend to use control system cable (16/0.2 or 32/0.2 depending on the load). Mains cable is not too bad, but you may be better stripping off the outer insulation. Best investment in my opinion is a big pack of tyraps and a big pack of cable tie bases. Tidy wiring is so worth the effort when it comes to fault finding and reliability.
Wom
Re: wireing
« Reply #4 on: May 02, 2008, 02:43:49 pm »
Car Accessory Shops,
I use mostly car equipment, fuses, fuse holders etc.
Garabaldy
Re: Wiring
« Reply #5 on: May 02, 2008, 03:07:10 pm »
cheers guys.  Does the same go for connectors etc aswell?
I think il have 36-48v and around 3amp running through them.
Its funny im asking all these dumb questions about wiring and connectors while im sitting at work drawing a schematic on autocad...........
wombat
Re: Wiring
« Reply #6 on: May 02, 2008, 03:36:05 pm »
Hi Garabaldy,
36V to 48V seems a little high to me - why so much? I would suggest that 12V to 24V is probably enough.
With these higher voltages, you will have to use mains rated fuses rather than automotive ones - certainly if you use 48V. Blade type fuses are only good to about 36V.
Connectors - if you use the red, blue or yellow crimps always use a proper ratchet crimp tool. The hand plier type do not give a reliable enough crimp. You can get them from car parts shops - better though to go to somewhere like Screwfix.
Wom
boatmadman
Re: Wiring
« Reply #7 on: May 02, 2008, 06:04:42 pm »
For small power use such as lights, I use alarm cable wire, lots of different colour cables.
Page created in 0.014 seconds with 20 queries.
