hi there TT
first of all, I think we need to understand a little basics about GRP (glass reinforced plastics) :
POLYESTER RESIN OR AN EPOXY RESIN
On their own they do not have any great strength values; if both materials were to be cast in an ingot form, and subjected to various tests - e.g. impact, crushing and bending tests they would fail miserably. Admittedly the Epoxy Resin would fair slightly better than the Polyester. We can assess from this that they are basically a 'bonding' or a 'cementing' agent. This is why we have to add a second component - tissue mat, as used by the fibre glassing industry, is matting that is made up of millions of strands of glass rods which are the same thickness approx as the human hair. These have been bonded together with a soluble agent in every direction on a flat plain. The same can be said about the heavier grades of matting. The two varients are the weight of the glass fibre strands. However, the lengths of each strand are normally equal.
So, the process now is when we add the resin to the matting, the resin disolves the bond in the matting and allowing the fibre glass strands to move freely in amongst the resin, being totally encased with resin. This is where the strength comes from and also it is why air pockets/any impurities are avoided.
WOVEN ROVEN GLASS MATERIAL
If we look at this material - this is a different system of matting. This is where the glass fibre strands are of a longer length and they go for many thousand metres; these single strands are woven together to form a type of string which is then rewoven, as one would weave a blanket/cloth. There is no soluble bonding agent to hold the fibres together, it relies solely on the weave. So, in this case, when we add the resin to the weave, the strands do not break down. They remain in the same weaved pattern - this material (when correctly applied) can be at least 3 times stronger than the chopped strand mat makeup.
Its downside though is that it is extremely difficult to work with being difficult to remove air bubbles from and get the resin to penetrate the fibres evenly.
You are asking for an alternative material; to add to the resin. So I do hope you can see that the material you intend to use will influence the strength or durability of your lamination
My advice to you is try to use a material where the fibres on the makeup will absorb the resin. This in turn will increase the strength. As a sidenote, some nylon materials, as in similar material to tights/stockings :) slow down now......can be used with great success.
Also, some of the nylons which have a 'flocked' side to its makeup can be used. These flock types do absorb the resin.
You will find that on some materials which do not absorb resin properly, when you sand through and you hit the reinforcement material that you have opted to use, it will be soft - where the resin either side will be hard. You will then get 'fluffy appearance' on the finished laminate, which is difficult to rectify.
Some thoughts for you......
aye
john e
bluebird
