Author Topic: Wire for handrails- what gauge ?  (Read 4628 times)
« on: May 21, 2008, 08:21:14 am »
I have some 1:72 scale stanchions to fix. Can someone tell me how I work out what gauge wire I need for the handrail and centre rail.
If I know which size brass wire (in thous) can I convert this some way to give me the gauge of copper wire I will need ?
Thanks. O0
dreadnought72
Re: Wire for handrails- what gauge ?
« Reply #1 on: May 21, 2008, 09:27:00 am »
Try this!
The first column is the gauge. Second column is the diameter in mm for that gauge in SWG. Third column is diameter in inches. And finally (because I'm using it myself!) the last column is a diameter in inches which at 1/72nd scale equates to a particular gauge. (So a one-inch diameter in real life is near enough 28-gauge.)
SWGSWG1/72nd diadiascalegaugemminchesinches103.250.12809.22112.950.11608.35122.640.10407.49132.340.09206.62142.030.08005.76151.830.07205.18161.630.06404.61171.420.05604.03181.220.04803.46191.020.04002.88200.910.03602.59210.810.03202.30220.710.02802.02230.610.02401.73240.560.02201.58250.510.02001.44260.460.01801.30270.420.01641.18280.380.01481.07290.350.01360.98300.310.01240.89310.290.01160.84320.270.01060.76330.250.01000.72340.230.00920.66350.210.00840.60360.190.00760.55370.170.00680.49380.150.00600.43390.130.00520.37400.120.00480.35
« Reply #2 on: May 21, 2008, 10:33:41 am »
Cheers Andy, that should do it thanks. O0
John R Haynes
« Reply #3 on: May 21, 2008, 10:41:28 am »
24 gauge will slip easily through my etch 1/72 stanchions . If you pull - draw soft wire to get semi-hard you, can use a slightly heavier gauge. www.johnrhaynes.com
« Reply #4 on: May 21, 2008, 10:53:47 am »
Thanks John.
truman06
« Reply #5 on: June 30, 2011, 05:01:13 pm »
Are these gauges right?
Page created in 0.616 seconds with 17 queries.
