Portside ll
To help us all it might be worth a little clarification - the polystyrene that you used must have been foam - not solid polystyrene sheet as used for vacforming and Airfix kits (also known as HIP or HIPS).
Similarly the resin must have been polyester - the car repair smelly one! As you have discovered it eats foam PS - all types
Ow Abreast speaks of High density foam from B&Q - if that is Ps it will vanish likewise (Jablite is a brand of expanded polystyrene foam)
if it is polyurethane (PU) material it will be fine, as will several others.
However DON'T even think about cutting PU with hot wire - it dissociates to gases including cyanides!
<<So tomorow its cut away the mess and make new styreen sections, so what should i cover the styreen with prior to GF ,i thought of paint or maybe pva and paper tissue >>
All of these are good - but if you have to GF it use epoxy resin as ukengineman says, or just paste on lots of newspaper with PVA or better still emulsion paint.
please keep us posted with chapter 2
andrew
