Author Topic: Discharge currents  (Read 3321 times)
bbdave
Discharge currents
« on: May 30, 2008, 05:43:11 pm »
Hi whats the maximum discharge rate for nimh cells a 7.2 3300mha for example
Re: Discharge currents
« Reply #1 on: May 30, 2008, 05:59:05 pm »
It all depends if they are racing cells or fully balanced cells.
There should be a spec for the cells available by the manufacturer.
« Reply #2 on: May 30, 2008, 06:09:07 pm »
The ones I've got from The Component Shop are 35 amp for the 7.2v 3300mAh ones O0
FullLeatherJacket
« Reply #3 on: May 30, 2008, 07:30:25 pm »
Decent packs will stand C10 i.e. 10 times their quoted capacity. Some NiCADs could stand much higher than that, but NiCADs are now history.
If the supplier can't or won't tell you then buy elsewhere. You will have no such problem with the supplier DickyD has mentioned.
FLJ
bbdave
« Reply #4 on: May 30, 2008, 08:44:00 pm »
Ok thanks  i'll ask them the question
« Reply #5 on: May 30, 2008, 09:04:02 pm »
bbdave
« Reply #6 on: May 30, 2008, 10:51:58 pm »
Cheers dicky these are the vapex packs i have so i assume they'll be the same
