Hi Guys,
Wow! Your ideas are coming faster than I can try them out. Many thanks :)
Last night, I tried a splash of acetone on the ballast in just one bay. It did soften the resin a bit, enough to prise out some balls with a screwdriver. After an hour or so I weighed the (small) tub of removed balls - gosh, a whole 150 grammes, out of the 3 Kg in the boat.
It got me to thinking - at last! - so I weighed some of the other bits-n-bobs as well:
The original Nicad pack : 600g
6V 4Ah accumulator : 800g
2 x 6V 3Ah accumulator : 1800g
and, of course, while doing the ballasting in the bath, I used the Nicad, set about midships.
but for 'sea trials' I used a pair of 3Ah accumulators set a bit further for'ard (cos they couldn't fit midships), never giving a thought to the ballasting situation.
Since the duration I got with two accumulators far exceeded my hopes, I think I can safely go down to just one, and that
will position midships.
So it should be 900g accumulator midships
instead of the 600g Nicad,
less 150g of ballast already removed from a for'ard bay.
Perhaps I'll try her out again this weekend.
And never again will I set my ballast in resin direct against the hull, Promise ::)
Geoff
