Has anyone any experience of using 2" foam slabs as a hull.. not as formers, not as a lost-foam process.. but as the actual hull?
The plan for a slightly fun, whimsical design is currently based around a 2" foam hull, either lightly clad with thin ply or sealed with acrylic varnish.. electrical gubbins to be in a seperate plywood box deeper than the hull and projecting through a well in the main hull.
This is just a very quick sketch of the construction method..
I just happen to have some foam about the right size to hand.. and it looks a cheap and rapid solution..
Will it work or is there a problem I've not yet considered?
Al
