Author Topic: The Gato has landed...  (Read 10670 times)
das boot
« on: June 06, 2008, 07:18:46 am »
Well, my Gato kit arrived yesterday after getting lost in transit once and being delivered to the wrong address three times, it made it safely here.
It's now takien over my desk, I had to rearrange the lounge furniture, and I've only just opened the box!
I'm after any interior shots of radio controlled Gato's please chaps...anyone who has built one, post me up some internal shots PLEASE!
Cheers,
Re: The Gato has landed...
« Reply #1 on: June 06, 2008, 08:28:09 am »
    It's a lot bigger than I imagined.  :o
moonlight
« Reply #2 on: June 06, 2008, 08:32:53 am »
Was that another entry to the caption competition?
das boot
« Reply #3 on: June 06, 2008, 08:41:22 am »
It surprised me too Martin...52" oal, nearly as big as a Darnell boat, bit slimmer in the beam at 4 1/2", so it may be a bit tender when running fully surfaced in rough water, but then who worries? Subs are designed to run at periscope depth!
As big as it may be, it's still going to be a tight squeeze to get everything inside the hull though.
Cheers,
colin-stevens
« Reply #4 on: June 06, 2008, 10:58:55 am »
have a gander at sub pirates. wonderfull build there from dave merriman. you can also buy ther gubbins for the inside of of a related site. nothing else will give you some ideas.
colin
grumpy old XXX
« Reply #5 on: June 06, 2008, 12:39:35 pm »
FYI. What a build masterclass!  - -  http://www.subpirates.com/viewtopic.php?f=31&t=2056&st=0&sk=t&sd=a&sid=ee5dd31c8a68c5d2a58642a9efabcd24
BTW: I see the kit is about £30 on ebay.... Hmmmmmmm!  ::)
das boot
« Reply #6 on: June 06, 2008, 01:41:46 pm »
Wow..that is one web page saved on my hard drive for future use!
I paID £30 for my kit from anticsonline off ebay...money well spent I reckon
Cheers,
colin-stevens
« Reply #7 on: June 06, 2008, 05:35:15 pm »
read some of his othr builds, the mans a genius.
also have a gander at the rusian thing being built on the targets page on sub pirates.
grumpy old XXX
Turbulent
« Reply #8 on: February 23, 2009, 09:34:18 am »
Better late than never! Here's some pictures of my Gato, she got her keel wet for the 1st time on Sunday & sailed well, although a little low in the water.
Pictures of her in the water to follow - they're on my son's camera!
Biggest issue is venting the air from under the decks, I've opened up a large hole under the tower as this is particularly bad here.
Currently running on 8.4v & 2 300 motors but this is way to powerful & will reduce the motor size at the first refit.
Props & A frames are from the kit & drilled out / threaded as required, shafts are brass 3mm.
Turbulent
« Reply #9 on: February 23, 2009, 09:35:08 am »
more..
Turbulent
« Reply #10 on: February 23, 2009, 06:27:01 pm »
more...
Turbulent
« Reply #11 on: February 23, 2009, 06:28:20 pm »
more..
Pointy
« Reply #12 on: February 23, 2009, 06:33:31 pm »
Looking good  :-))
Love the weathering, was it difficult to cram all that gear into the hull? What kind of diving system does it have?
Turbulent
« Reply #13 on: February 23, 2009, 06:45:34 pm »
There's enough room because I've got the motors & batteries in the wet compartment.
It's a simple water pump with an additiional air tank in the bow to allow more water capacity.
sheerline
« Reply #14 on: February 23, 2009, 10:10:00 pm »
Boat looking great Turb, the water is looking quite clear too, makes a change!
Turbulent
« Reply #15 on: February 24, 2009, 09:53:53 am »
Thanks Chris
The water is the clearest I've seen it here's the old man's Akula on the bottom.
sheerline
« Reply #16 on: February 25, 2009, 12:14:37 am »
Looks like I will have to get the Type2 out of dry dock soon then, I would like to get some more video shots and maybe a few underwater pics.  I had also better start rousting Kapitain Pond and get both our boats underway again. One or two customers threatening to bring their Type2s up there  as well, so could have a flottila up and running one day.
Nice to see the Akula's still going strong.
Trouble is, turning into an old git and losing a bit of weight means umpteen layers of clothing, gets ruddy cold up there sometimes!
Don't laugh, you all got it comin one day!! :((
Turbulent
« Reply #17 on: February 25, 2009, 10:04:41 am »
It was bloody frezzing on Sunday - I dont have the lack of weight issue either!
The good thing about sailinf in the cold is water calrity, as soon as it warms up a couple of degrees it will probably colour up as in previous years.
You'll do well to get the Kapitan out of his cave yet!
I've re joined NMBC now & might speak to the committee about reforming the Submarine section, I think there's still plenty in the club.
Looks like there are 2 Sub Regattas planned this year.
ivorthediver
« Reply #18 on: March 07, 2009, 06:37:34 am »
Hi guys, I have a surface runner of this kit, and another as yet unbuilt.
Can you advise me as to where to start looking at and for.. the electricory inside please.
I note that you are useing 3mm brass rod for your propshafts.... will these not warp ?
I have been advised that White Steel is a better answer... any advice Here
What RX/TX do you run with please   %)
colin-stevens
« Reply #19 on: March 07, 2009, 07:06:40 am »
what wtc are you using, or did you DIY?
looking very good
colin
grumpy old XXX
ivorthediver
« Reply #20 on: March 07, 2009, 07:37:50 am »
looking very good
colin
Thanks for responding Colin
As of yet nothing , but have looked at several options but can't make up my mind or find anyone who has gone down this road yet.....
I currently run a "Manxman"greyfleet and wish to look into a submarine set up. where I "float my boat" is deep and murky so would not wish to go below conning tower
and I am running on a "Spektrum" set up
Turbulent
« Reply #21 on: March 07, 2009, 04:09:48 pm »
3mm Brass rods are fine on a boat this size - I've fitted them in bigger boats pulling more torque.
I always run 40MHZ in fm for subs-  better reception when dived.
The WTC in my boat is my own as detailed in Marine Modelling a while back by Paul Cook - pm me for more info'.
Motors & Batteries are fitted outside the WTC - motors are in 35mm cannisters & packed with Grease.
colin-stevens
« Reply #22 on: March 08, 2009, 08:50:54 pm »
Rich, which WTC are you using, or is it DIY?
colin
grumpy old XXX
Turbulent
« Reply #23 on: March 15, 2009, 06:08:48 pm »
Took her out for another batch of trials today - nearly there but I think she needs a leveller - Mike are you listening??!!
Turbulent
« Reply #24 on: March 17, 2009, 10:57:01 am »
My Favourite Pick So Far - Cheers PC
