Author Topic: voith unit  (Read 10309 times)
lighterman
voith unit
« on: June 10, 2008, 09:22:05 pm »
has anyone ever read the couple of books written about building voith units in model form? they are both in german.
And out of interest the graupner versions what sort of size are they?
pioneer
Re: voith unit
« Reply #1 on: June 10, 2008, 10:18:56 pm »
Hi lighterman
The Graupner voith units stand around 15cm in height from the tips of the blades to the top of the motor, 5cm of this is the length of the blades. To fit them in a hull requires an 84mm hole into which a mounting ring is fitted allowing the unit to then be secured to the hull.
Hope this helps O0
Andrew
Umi_Ryuzuki
Re: voith unit
« Reply #2 on: June 11, 2008, 01:00:42 am »
There are actually three books, all in German, and I haven't read the two I have, because,..
Well they are in German.
I have yet to find a copy of the book by,
 Theodor Vieweg ISBN 3-7883-187-2
"Der VSP-Antrieb im Schiffsmodell"
The second by,
Kurt Benz ISBN 3-922414-10-9,
 "Der Voith Schneider Propeller als Schiffsmodellantrieb"
Sometimes pops up on e-bay. it has plans for a four blade drive approximately
 95mm in diameter with 15mm wide x 47mm long blades.
The third book is on e-bay regularly. MTB Modell-technik-berater - MTB30
"Voith-Schneider-Antrieb im Selbstbau"
by Hubert Bossart/ Eberhard Schulz Isbn 3-88180-374-2
Drawings to build a four blade drive approximately
 114mm in diameter, with 20mm wide x 50mm long blades.
Of course once you have the plans, it would be possible to
enlarge or reduce them as you see fit, or as
 your skill level and machine tooling  allows.
The old graupner 1768 drives are
 84mm OA in diameter with five blades approximately  10mm wide x 27mm long.
HT OA 91mm
The new 2002 Graupner 2358 drives are
 93mm OA in diameter, and have five blades approximately 17mm wide x 50 mm long
HT OA 155mm
lighterman
Re: voith unit
« Reply #3 on: June 11, 2008, 08:27:59 am »
Thanks for the replies! i will have to check them out!
Umi_Ryuzuki
Re: voith unit
« Reply #4 on: January 30, 2009, 06:06:53 am »
The older book currently on thE bay....
Der Voith-Schneider Propeller - Schiffsmodellantrieb
- vom Kurt Benz
http://cgi.ebay.com/Der-Voith-Schneider-Propeller-Schiffsmodellantrieb_W0QQitemZ360127175507QQihZ023QQcategoryZ32142QQssPageNameZWD1VQQrdZ1QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
Item number: 360127175507
toesupwa
  • USA'd ex Brit
Re: voith unit
« Reply #5 on: January 30, 2009, 02:19:00 pm »
It isnt now...  :-))
Umi_Ryuzuki
Re: voith unit
« Reply #6 on: January 30, 2009, 06:20:40 pm »
It isnt now...  :-))
Help me build 50 - 65mm diameter drives... %)
toesupwa
  • USA'd ex Brit
Re: voith unit
« Reply #7 on: January 30, 2009, 06:29:32 pm »
It isnt now...  :-))
Sure... how many do you need?...  %)
Re: voith unit
« Reply #8 on: January 30, 2009, 06:36:08 pm »
Hi Umi how come half your website has nothing on it ?
Umi_Ryuzuki
Re: voith unit
« Reply #9 on: January 31, 2009, 12:01:24 am »
Seems to be server issues... {:-{
andyn
Re: voith unit
« Reply #10 on: January 31, 2009, 01:31:00 am »
If you go into a page and press F5 to refresh the page does come up.
Lovely looking models there, where'd you get the resin anime kits?
Umi_Ryuzuki
Re: voith unit
« Reply #11 on: January 31, 2009, 02:34:21 am »
The anime charactor, Sailor Saturn, was ordered out of Japan.
http://www.hlj.com/
It was my first figure kit.
It isnt now...  :-))
Why two of course, with slightly oversized blades...
 Maybe I bring my mill and lathe over, and copy you as you work...  %)
toesupwa
  • USA'd ex Brit
Re: voith unit
« Reply #12 on: February 05, 2009, 11:37:40 pm »
It isnt now...  :-))
You aint going to believe this... the book is here!...  :D
Incredible service!..
Umi_Ryuzuki
Re: voith unit
« Reply #13 on: February 26, 2009, 07:52:43 pm »
Another has come up.
Get it before toesupwa does...  ok2
http://cgi.ebay.com/Der-Voith-Schneider-Propeller-als-Schiffsmodellantrieb_W0QQitemZ370165142293QQihZ024QQcategoryZ32142QQssPageNameZWD1VQQrdZ1QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
Item number: 370165142293
von Kurt Benz
toesupwa
  • USA'd ex Brit
Re: voith unit
« Reply #14 on: February 27, 2009, 09:56:01 pm »
Now, what would i do with another book Umi?...  %)
mike_victoriabc
Re: voith unit
« Reply #15 on: February 28, 2009, 06:26:02 am »
might have hooked it if I read their info correctly!
Page created in 0.306 seconds with 17 queries.
